Its 240 volts
SOURCE: I am installing a Dayton G73 heater. With dryer cord
http://images.google.com/imgres?imgurl=http://www.fixya.com/brands/manuals/G/GE/dpsb613dww_d_be1e2bf7aaa668c5b0dad43b3ea2fe50/images/BA1EC45DEA535C0AF937115EB13C6B38.png&imgrefurl=http://www.fixya.com/support/p129426-ge_dbsr453ebww_dbsr453ebcc_electric/manual-13167/page-3&usg=__0xzv1eHbsRHGvV64tuqgmf1SFTk=&h=1037&w=791&sz=5&hl=en&start=18&um=1&tbnid=SvaQyvdl35_zxM:&tbnh=150&tbnw=114&prev=/images%3Fq%3D30amp%2Bdryer%2Bcord%26hl%3Den%26rls%3Dcom.microsoft:en-us:IE-SearchBox%26rlz%3D1I7ADBF_en%26sa%3DN%26um%3D1
Look at the diagram here. It is actually called the neutral wire with a hot lead on each side. The new 4 wire dryer cords actually have a ground and a neutral. The neutral and the ground are usually hooked together or "bonded" in a breaker box. Heater draws 21 amps so you should be good to go.
Testimonial: "Thank You"
SOURCE: I just need a wiring diagram---with a thermostat--
grainger has them- home depot. wire is easy wire one side straight to 1 wire on in coming power the other side use your thermostat to break curcit ie wire into stat out of stat to voltage
SOURCE: craftsman radial arm saw 113-197751 wiring diagram needed
A friend just inherited a model 113.197110 and we are in the process of trying to restore it. I can draw you the wiring connections if you haven't figured it out yet.
SOURCE: wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
SOURCE: I need wiring diagram for a Broaster pressure fryer Model 1800E
I have a service manual for the 1600 and 1800 Broaster and it has wiring diagrams in it
