Hot water heater keeps sparking after burners lit.
The igniter probably did this prior to the adjustment if not check manuel if this not a safety back up to prevent gas from not being burned .
There is a small piece of metal that the pilot flame touches. With the unit off, clean it with a Scotch Brite pad, pencil eraser or dollar bill. The computer is likely not getting the signal saying you have a flame (or it is intermittent).
Good luck and please let us know if that worked for you. If you would rather replace the part (generaly a good option), please let me know and I can send one to you.
Sounds like the flame detector sensor and circuitry is saying no flame, relight'
SOURCE: pilot lights (not always) but gas will not flow into burner
First Clean the ignitor assembly and make sure the flame is reaching the flame sensor strongly.
You may need to replace the flame sensor.
SOURCE: no hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
SOURCE: Bosch Aquastar tankless water heater model
There should be a thermocoupler, it is that bulb that sits in the pilot flame. If it is not functioning properly the main gas valve will not open.. Hmmm, Is the main valve in the on position?
SOURCE: Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
