All of a sudden, one single line connected to our TD1232 has gone dead. I've checked with the phone company and all is fine. the number rings constantly when it is called but internally, there no indication that a call is coming through. When you try to select that line to dial, it is completely dead (No dial tone) There are 6 standard telephone lines in the PBX. The problem is that the line in question is part of a rolling hunt group (not from the phone company) which when lines 1-2 are occupied, the line in question just rings instead of rolling over to the next 3 lines, thus making it seem like nobody is at the business. Lines are good and I've even physically switched around the incoming lines on the TD1232 to see if that makes a difference and it doesn't. The phone company indicated it may be a problem with the TD1232 but how can I tell. I've reset, rebooted, and killed the power for 5 minutes. No changes. Please advise
Ok so the first thing you should do is to get to where your PB X connects to the lines and ensure that there is a standing voltage on the lines. usually 50 v dc in the uk.
check each line has 50 volts with a multimeter when nthey are not active.
if line 3 has no voltage your problem is the line.
if line 3 does have voltage at 50 v idle ring the lines out 1 then 2 then 3 foir a analogue line to present ringing bthe voltage increases and is in cadence with the ringing. if again the voltage does not increase during the ringing cycle then the problemn is again with the line.
if the line 3 has 50 v idle and increase in voltage during ringing, then the problem is the line interface in the PBX
hope that this helps all above is for analogue lines only
SOURCE: Incoming Call not Ringing
Either call line 3 first, or make your phone ring :-)
What might be the easiest is to swap modular plugs in the back room between 2 and 5. That way, you get your old extension back and everything will work as it did.
If you can't do that, then you're going to have to do some system programming to turn on the ringing on your phone. If you have a TA series system, you should be able to do it from either the PC or a phone connected to jack $1. If you have another model, you should have a system manual on how do make programming changes.
Carl
SOURCE: i have no dial tone on one line. call my number and it rings
IT IS DUE TO NETWORK FAILURE OF THAT LINE
SOURCE: no dialtone
If you use Dsl as a internet provider make sure you have the filters on each phone. If you use cablevision and have a wireless connection make sure you chage the phone to a 5.2ghz because you might have the wireless router with the same ghz causing a coflict. This will also create loss. of internet connections then you use the phone
SOURCE: Unable to hang up phone. The line is busy/can't make/receive call
sounds like you need a DSL filter, go to page 41 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
SOURCE: Is tha possible to get 25 single lines on 16SLC card(50 pin)
This is my first time installing the 3 expansion modules on 1232 pbx. I'm installing 16SLC Card (KX-TD174) and KX-TD1232 PBX. I have installed it in the expansion area 1,2,3 and put the internal screw already. I programmed using #109 with C,A1,A2 for three kx-td174 unit but no slave displayed However, I cannot be able to hear the dial tone but I hear fide power in the area 1 when I attach a single line telephone to the jack. but area2 &area 3 is working properly
You have this posted in the wrong product category. Please select another category appropriate to the problem.
