Phone bleep when lifted indicating message but on checking none there how to remove the bleep for this ghost message it would be of great help
SOURCE: message waiting indicator
Try holding the mute/find handset button on the base unit for about 5 seconds and the light should stop flashing.
SOURCE: ge model 28112 dect 6.0
If you restore Factory Defaults under "Mute" menu it will stop blinking.
SOURCE: MLX-20L - Message light is on but there is no message
Press Menu, then Msgs, then Delete. It's some internal phone thing.
SOURCE: The VM indicator displays on my handset but there are no messages
I saw that someone else posted this solution and it worked for me. Unplug the power on the base unit and then reconnect the power while holding the "find hs" button. I just did this and it fixed my blinking light problem.
SOURCE: voicemail light is flashing. How do I get message?
If you have a voice mail box set up, and you don't use your answering machine for messages, that would be something that is set up through your phone company (AT&T, Verizon, etc.).
Typically, to access your voicemail, you would dial your home phone number, and then when your message picks up (either the automated message or your personal greeting) press the asterisk or star key (*) and then enter your password. Depending on your particular voicemail, you may have to hit the pound key (#) after your password as well. Then, once you are logged in, the system should tell you whether or not you have any new messages, and if you do, generally you would press "1" to hear them.
Hope that helps! If you can't get in to your voice mail or your password doesn't work, you would have to contact your local phone service provider for assistance.
