Vehicle Parts & Accessories Logo
A
Anonymous Posted on Jul 23, 2014
My viper alarm dash light wont stop blinking my remote has a aux button
Derrick Schultz
Level 3:
Top Expert:
  • Vehicle Part... Master 11,405 Answers
  • Posted on Jan 31, 2019
Derrick Schultz
Level 3:
Top Expert:
Answers
11405
Questions
0
Helped
2328571
Points
23972
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
1 Related Answer
Anonymous
  • 5 Answers
  • Posted on Oct 09, 2009
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
2helpful
2answers
I think I messed up the remote programing.. When I press to lock the doors they do lock but the horn doesn't honk anymore.. The blue light on the dash does not light up either.. I can still remote...
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
I am trying to disarm the viper 5701 2 way alarm w/ remote start and the keypad nor is the manual override responding. How can I disable the alarm?
Get in car........alarm will be going offVisually find the black valet button..........it should be next to led on the antennaTurn key to IGN position...........so all dash lights are onWithin 5 seconds push the valet button 1 time..............may have been programmed to more times, but ussually notSiren should stop and you can start the car.
TO put into valet mode
Key to IGNKey to OFFPush valet button 1 time.Led should now be solid.
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
The alarm is on a 1996 f150 the alarm will not chirp the led on truck is solid it isnt blinking and it is a 5701 viper
Your alarm got put into valet mode some how
.It's easy to reverse out of it back to normal. First look for a small black push button under the dash somewhere. It's called a valet button. Here are the steps.
1. open door
2.turn key on then off
3.then within 10 seconds hit that valet button once(your alarm light should be off. Tell you arm it again. Then it will blink)
Hope this helps
I hooked up my alarm and when I hit the remote start button, car does not start. Then the dash lights blink 7 times and the blue led on the valet switch blinks 3 times over and over.
Thanks for writing to Fixya.com .
This sounds like a bad fuse. The fuse is likely under the dash below on the driver side. Look up under the dash below the steering wheel and confirm location. The fuses will either be plugged into the module or as in line fuses coming out of the unit.
Thanks for contacting Fixya and please accept the solution if it has helped you.
7helpful
3answers
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
1helpful
Viper 771 Remote start/Alarm
the viper alarm is malfunctioning , it is supposed to bypass the key ignition and or chip in the key to allow it to start , you will need to look for a reset button( under the dash and just two wires going to the button)( stuffed under the dash ) ( not the switch) , this should let you start it but if the alarm components that control that bypass is to far gone then this will not help and the alarm will need repair , replaced or removed
1helpful
Viper Alarm System problem
Look for a push button under the dash, should be black, turn key on and hit button.. should go into "valet mode".. hopefully you will be all set...
59helpful
2answers
Viper auto alarm stuck in valet mode
u can open the drivers door if u have a 2 key remote just press lock aux lock again pretty fast and u should be great.
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
