Rider
SOURCE: How do I install a mulching Kit on my Husqvarna
having trouble with mulching unit on 22hp tractor.Mulching kit installed by dealer at time of purchase.What is happening is grass is kicking up on the top of the mowing unit,covering the belts and everything else.I need to do a major cleaning every time I use the tractor.Any one got some solution.
SOURCE: My 2 year old Husqvarna riding mower, with the
I too have had that same problem. I found that "old" blades when repeatidly sharpened and worn will cause the same problem, also aftermarket blades instead of original manufactures recommended blades may not be dimensionally correct, too short. I have had to go back to using original blades to correct the problem.
This should work for you.
Good luck.
SOURCE: How do you remove the mulch plug off a Craftsman YT3000 riding mower?
most are just held in with a couple of bolt
SOURCE: how to fit mulch blades to Husqvarna ride on tractor mower
if you have the right side you just bolt them on to the shafts
