Error code for a shorted membrane keypad switch. Manufacturer suggests unplugging the unit for an extended period of time to see if the control panel will clear the code. If not, then you probably have a defective switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
SOURCE: 5E error message
"SE" means you have a shorting membrane keypad.
If and when an oven
is coming on or doing anything by itself, this is very dangerous and
can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open when it's not in use, and please do not leave it running
unattended.
On most Samsung models, your best bet is to buy a whole new control box and replace it.
This is a simple do-it-yourself job.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you do not find information about your model or you need more help, note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So please post a NEW question, and please
include your brand name and the full model number from the tag in or on
the unit
SOURCE: We are getting an error code of 5E. Microwave
"SE " means your membrane keypad is shorting. And it is specifically the baked potato key that's shorting.
If and when an oven is coming on or doing anything by
itself, this is very dangerous and can result in a fire.
open when it's not in use, and of course one should never leave a microwave unattended while cooking. Better still, unplug it and do not use it.
We would need the model number in order to provide you with free assistance.
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions or contact us here for free assistance.
SOURCE: samsung microwave smh9187w SE error
this mean problem with the main control board. I hope this help you
God bless you
SOURCE: samsung smh9187w repair manual
go to www. pdfservicemanual.com or wwwmanualsfactory.com
God bless you
SOURCE: My Samsung microwave SMH9187W is
Maybe Just Lucky; I removed the front cover above the door by removing the two screws on top of micro. Then I removed the screw above the controll panel and carefully lifted off the panel. I checked all wire connections while plugged in and the SE code changed to 0. I reset the clock and put the panels back on.
Done Loose Wire
