Water Heaters Logo
A
Anonymous Posted on Jul 22, 2014
What is error code 14 for a Bosch kitchen controller
The controller is showing 14 in the display and its getting harder to get the temperature to reset
1helpful
Can you help with these Bosch 715 EFS GWH Error Codes? AF, 40, 07 -
https://www.fixya.com/support/t13643459-a2_af_error_codes
Bosch hot water error 14
hi julia
after checking on your bosch water heater error code e14
you can try to reboot your system but if code comes back you may need to find a plumber that knows your system to fix your fan system and clear your fault code. this is the site i got info from
http://www.jimsplumbing.net.au/bosch-hot-water-system/troubleshooting-guide/error-code-e14/
p.s. this site is not in the usa
How to change from ºF to ºC on the UMC-117?
According to the 2012 manual, 'the LED display only shows F.'
Bottom page 65. Yet the F temperatures are also shown as C in the manual.
http://waterheatertimer.org/pdf/How-to-set-Rheem-tankless-temperature.pdf
You probably have different model, or older model?.?
Older manual (page 15) shows same temperature range with both F and C, but typical of Rheem, the manual is totally vague about settings and say that qualified tech needed to adjust temps beyond factory default range (with no mention of display showing C) ... which is safeguard since the damg product cannot always heat water fast enough to reach higher set points above 120F.
http://waterheatertimer.org/pdf/TanklessOutdoor_95_84_64X_UC_AP15318.pdf
Call Rheem 800-432-8373 and give your product serial number and model number located on side of unit, and ask them.
Don't forget to keep the product maintained to avoid common error codes.
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Error code el
Code EL does not show on typical Bosch error code list.
Maybe you have E1 ??
Or Bosch has some other error codes not listed.
http://waterheatertimer.org/pdf/Bosch_E1_troubleshooting.pdf
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.bosch-climate.us/support-center/technical-support/
My Boch 24ES Highflow Hotwater is showing Code 14 and only runs for i minute then shuts off
Code 14.
What water heater do you have?
Question posted under tankless Bosch, but these error codes start with a letter.
Rheem/Richmond etc Tankless has error code 14
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
Call tankless service technician.
Ask technician how much it costs to have recommended yearly service.
Or install whole new tank-type gas water heater yourself for $350 from local box store, and avoid the entire headache, then sell tankless online for parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
My Bosh 24ES has error code 14 what does this mean and can I fix it
The year 2009 Bosch 24ES manual does not show error code 14.
Your manual may be different.
Call Bosch 1-800-642-3111
http://waterheatertimer.org/pdf/Bosch-GWH2400ES.pdf
Don't forget to read the product manual for required yearly maintenance, and performing this maintenance will eliminate many common error codes.
Error code e2. inlet water temp sensor. any one have to fix this?
Before calling service technician, open following link for Bosch troubleshooting resources, including error codes, manual, Bosch contact info, and service bulletins.
Error codes are starting point for troubleshoot.
e2 is cold water temperature sensor fault.
Bosch error code says: 1) Check connector on wires coming from top of water valve for a secure connection.
2) Sensor may trip if water temperature drops below freezing to protect heater from freezing conditions Any damage due to freezing conditions is not covered under warranty.
Another contributing cause can be temperature thermostat set very high and tankless sensor is going bad, and very cold incoming water, or combination of factors above.
Also read manual for advisories and required maintenance. Some units require water filter be cleaned monthly.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
12helpful
2answers
I have a bosch YS2433R 'Highflow' hot water system. It has a YPRM34XB controller. The controller constantly flashes the number '99'. My home has no hot water. How do I fix this error on the controller so...
Solution for a code 10 or 99 (for my own reference as much as anything!)
Hit change and the down arrow on the controller for 3 seconds.
Wait for the controller to beep and display 00 before using the down key to display 93.
Hit the On/Off button until 000 is displayed on the screen.
Press change and down simultaneously and the controller should revert to the pre set temperature. Hey presto! Hot water!!!
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
