Yesterday we upgraded our internet speed and today the wii does not work
Hope this helps : Wii Console Won Turn On and Has No Power Light Wii and Wii mini...
If you need further help, reach me via phone at https://www.6ya.com/expert/timothy_c6f309c0f75b6f43
SOURCE: Wii worked fine yesterday. Will not power up
This
is a common problem with the Wii. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii. It happens
almost every time there is a power surge or the power goes out, etc.
Even
if it's hooked up to a surge protector, this happens. Power comes back
on, but the Wii appears dead. It won't turn on, and the LED indicators
won't light. If there was a power surge, or the power went
out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset.
Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug
it from the Wii, it has to be at the outlet. You have to kill power to
the adapter.
Unlpug it from the wall/surge protector outlet,
and leave it unplugged for 5 or 10minutes. This will kill power to the
AC adapter, and give the circuit time to reset. When you plug the
adapter back into the outlet after 10 minutes, the red led on the front
should be lit up.
SOURCE: internet 4 wii
There is a USB adapter that you will need to buy that will enable you to use an ethernet cable to hook to your Wii to get internet.
