Getting power to switch but will not come on
The easiest thing to check is the brushes. Unscrew each black (sometimes white) round cover on either side of the motor housing and see that there is enough carbon brush remaining.
Since the brushes were most likely ok, then I would suspect the solid-state control phase board. These are pretty easy to replace. You can find the service manual for your model on line.
SOURCE: MODEL KP2670 KITCHEN AID MIXER,IT WON'T TURN,POWER
fault in the armature is a possibility. danger of electrocution if you try to self repair. See service centre
