SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
SOURCE: nordic track X9i controls not responding
Dear Sir:
Adjust the reed switch, see the diagram attached, clean, and tight the connector very well.
Anyway I recommend to call the service Help, in the place where you did buy your treadmill.
However you can RUn THE SOFTWARE calibratin for diagnose, troubleshootin, and fix it, follow the steps in your instructions manual.
sincerely. God bless you
