No jumper settting are visible
SOURCE: how to connect two hard disks
Japanese Pantyhose Foot **** & Asian Footjob Nylon DVD http://www.avleg.com
SOURCE: jumper settings for a Maxtor Model 52049U4 internal hard drive
Look on the label on the drive itself
SOURCE: jumpers guide Maxtor 2B020H1 20Gb Slim IDE 3.5'' Hard Drive
Maxtor jumper as follow:
looking at the connector top row 5 pins, buttom row 4 pins.
the single pin on the top row is index pin.
master jumper is located between top 2nd pin and 1st buttom, counting from the left.
slave has no jumper on any of the pins.
cable select jumper is located between top 4th and buttom 3rd pin. counting from the left.
SOURCE: Duel Hard drive trouble
Your Os should have the main automatically, keep the other drives as slave unless they are usb then they should auto pick up when you start up your pc for sata drives you got to buy sata connectors and make sure your motherboard has more then just 1 sata connection. After you find out how many you have on your motherboard from bottom to top is 123 so if u have 3 then if you want like if you have a music hard drive and you want it to be first then put it at the bottom 2 and so on.. don't forget to set them as slaves
Testimonial: "EXTREMELY fast responce !"
for ide usually located on the top of the hard drive is the diagram
sata drives will automatically designate master slave
single or master :::::
master with slave ::'::
slave :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope it helps
