Www.allbrochures.net Canon imageRUNNER 3300 All Brochures
SOURCE: Scanning
joslloyd universal send is not available on the 3300 but it is on the 3300i.
You link to an old version of scangear software. Use http://downloads.canon.com/cpr/software/devicemanagement/NWSG_v2.21.exe
On the 3300 press System/Options button, One of four buttons far right, next to copy, fax, mailbox.
Press Online.
Read the manual included with ScanGear for how to set it up. Or ask if you are having difficulties.
SOURCE: how to load staples in canon imagerunner 3300 copier
Does your copier have the finisher or saddle to have staples? There should be instructions in the user manuals for replacing staples. If you don't have the user manuals, I'd ask Canon to purchase replacement copies or look on the web.
SOURCE: our copies are streaky like the drum is not
Horizontal streaks are usually the toner cartridge or the drum; vertical steaks are usually the thermostat or the fuser.
If you are getting horizontal streaks and changing the toner cartridge out fixes the issue temporarily, I suspect you probably have people taking the blank pages that print out after printing and feeding them back through the printer to save paper. The old
paper picks up a charge when fed through the first time, pulls toner up
the second like a magnet, and deposits the toner onto the toner drum.
When the next sheet comes through, the image itself or a black line of toner can be pulled from the last sheet
(or the sheet before) and is transferred over the new image. Change your
toner and print several pages to the printer, see if the problem fades
and goes away.
If it does, just tell people to either stop feeding the blank
pages through, or to at least turn them over and put them at the bottom
of the paper stack. This will give it time to dissipate the charge
before feeding back through.
