SOURCE: brewing instructions
Go to this website fopr brewing instructions:
http://www.bunn.com/retail/service/faq.html
Thank you for using FixYA
SOURCE: my bunnomatic commercial coffee maker is
If this unit is new and it is doing this, contact the company you purchased the unit from. They should make the adjustments needed.
If this is an old unit, and this just started, you may have a scale build up in the water supply. If that is the case, then it needs to be de-scaled.
The system uses a timer and solenoid valve for controling the water supply. If the valve is scaled up, it will not work correctly.
Also change the in-line water filter.
SOURCE: COFFEE MACHINE KEEPS FIL;LING UP AND OVERFLOWS.
Dunkin Donuts decaf coffee clogs the filter as the water fills the basket causing the basket to overflow. The coffee is ground too fine. Swtich brands or use a second filter to cover the coffee grounds to keep them from floating and clogging the filter.
