Uniden Solara DSC VHF Marine Radio Logo
A
Anonymous Posted on Jul 21, 2014
How to install a marine radio
Installation
Steve
Level 3:
  • Uniden Master 696 Answers
  • Posted on Jan 18, 2015
Steve
Uniden Master
Level 3:
Answers
696
Questions
Helped
239100
Points
55809
Hi!
Here is the link to your owners manual and installation instructions begin on page 7.
(If you have the white model, the instructions are still the same)
Hope this helps you out.
-Steve
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/SOLARA%20DSC-BKom.pdf
I want to mount an antenna to my boat's Aquatronics MS1550G
The Aquatronics MS1550G is a marine stereo, not an antenna. If you are looking to mount an antenna to your boat, you will need to find a suitable location for the antenna mount and then run the coaxial cable to the location where you plan to install your marine radio.
Typically, the coaxial cable will run from the antenna to a hole or grommet in the boat's hull or deck and then be connected to the back of the marine radio. The specific location and process for running the cable will depend on the type of antenna and the layout of your boat.
If you are unsure of the best way to install your antenna, it is recommended that you consult with a professional marine electronics installer or refer to the installation manual for your specific antenna and radio
Sep 14, 2018 • Boating
Will a Midland 75--810 communicate with a marine band radio?
Sorry Paula
The 75-810 is an CB radio that DOES have Wx capability but it won't communicate with marine band VHF's.
Hoe this helps you out.
-Steve
Oct 31, 2015 • Boating
Cobra mr f55-d engine noise
Most of the problems associated to "whine" sound on radios can be eliminated by installing a noise filter(capacitor) in the feed line. This product is readily available at electronic supply stores and I not very expensive. It usually comes with installation instructions. Make sure it can handle the amperage.
Hope this helps.
My radio will not transmitt but it receives just fine
Most problems with radios that receive but do not transmit are antenna or antenna wire/connector issues. It's easy to receive with a marginal antenna but transmitting requires a good working antenna. If you have a SWR meter or can get your hands on one, install it in line with the antenna and test for reflected power. Of course, make sure your TX light comes on when you depress the mic switch. If not, switch mic and try again.
Hope this is helpful! Reply if u can.
Will i need to mount a separate fm antenna when i install my new radio this spring?
Hi!
Yes, you'll need a marine VHF antenna. They're widely available at any marine store. Hope this helps.
Happy Boating!
1helpful
Ihave an old icom icm- 55 marine radio what ariel do i need and do i need to swr the ariel will a cb ariel work basically what do i need to do to get it working
All marine VHF radios must be licensed. A marine radio station must also have a call-sign allocated to the vessel it is installed in. Shore based stations can also be licensed but only where they are involved in marine based activities e.g Yacht Clubs, Marinas, Harbour Masters, Rescue Services etc.
In the UK ships radio licences can be obtained from Ofcom. They are free for non-commercial users.
The user must also have a Marine VHF Radio operators certificate. This requires taking an exam. In the UK contact the Royal Yachting Association for a copy of the syllabus and local examiners.
More information about the licensing rules, courses and exams can be found here. http://www.rya.org.uk/infoadvice/regssafety/Pages/licensingelec.aspx
The ICOM ICM55 is a good radio set and can still be used in an existing (marine) installation but it does not meet the standards for new installations as it does not have DSC (digital selective calling) capabilities - which all new fixed sets must now have. It is therefore very unlikely that you will be able to get a licence to install one.
To get it working you will need a proper marine band VHF aerial which operates in the frequency range 156-MHz. They usually come with cable attached but if a longer cable is needed, or the aerial is not cabled in the first place, use flexible 75 ohm co-axial cable with a copper core and braid/foil screen. Use proper aerial connectors (type F or BC are most commonly used and can be obtained from most good electronic component suppliers more cheaply than from a boat chandlers. Do not use push-fit TV aerial plugs)
Citizens Band radio works on the much lower frequency MHz band and therefore a CB aerial will not work with a marine VHF radio set. Please see this Wikipedia article for more information http://en.wikipedia.org/wiki/Marine_VHF_radio
Which antennae to use with a Uniden Oceanus radio?
Marine two way radios operate on 156 MGZ. You have to use an antenna desinated for that purpose. Type marine vhf antenna on google search and it will pop-up lots of web sites.good luck
2answers
Transmits but does not Receive
Check your microphone by swapping with another duplicate. If no differance, you will need a SWR meter (standing wave ratio) to find the culprit. It attaches in line of the coax and determinds power out and reflected power. The reading should be 25 watts foward and max of 1 reflected.
2answers
Sony Marine Radio
check the wiring is installed correctly make sure you have a good earth & if it is a detachable face make sure the face is on correctly after trying this hold reset button for 15secs
Top Uniden Boating Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bob G
Mike Cairns
Mike Cairns
Are you an Uniden Boating Expert? Answer questions, earn points and help others
