Question about JBL On Time Docking Station for Apple iPod (ONTIMEBLK)
Docking station instructions
Why does my jbl on time docking station cut out after I have set clock and try to switch to radio
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: My JBL docking station is no charging the ipods or
When you first got the speakers it should have came with a plastic insert that you put over the actual place you put the ipod on to charge. I know that you definetly need it for the movie playing ipods but not for the older ipods
Posted on May 11, 2010
harri193
SOURCE: i have a jbl docking
You can pick up an ipod docking station adapter here.
Posted on Nov 22, 2010
Ivo Linssen
SOURCE: i have bought jbl on time 200P dock station for
Hi. Try this: change your language settings to a European language. After that you can choose your radio type: choose Europe. Exit the menu. Now you will be able to choose radio stations with two decimals, for example fm 88.15. I hope this solves your problem.
Posted on Nov 13, 2011
How do you set the time on RC591-A (RCA Docking Alarm Clock)
None of these answers works! When I tried the first option, the clock DID NOT flash at 12:00 a.m. Since that didn't happen, none of the following steps did either.
The second option didn't work either. Holding the set key never made the display go to a colon, flashing or otherwise. Again, using the forward and back keys didn't work as described.
The third option with a link to another website led to instructions on a power tool and had nothing whatsoever to do with the clock on the docking station.
The fourth option doesn't give any instructions after you hit the time you want to set. The time DOESN'T stay where you set it. It once you release the forward or backward keys, it reverts to the original time that was on the clock to begin with.
None of these answers works at all. I was given the iPod touch and the radio docking station secondhand from my sister and she doesn't have either the instruction manual or the special batteries that go in the battery compartment. The clock on the iPod itself is fine. I finally figured out (on my own) how to turn off the danged alarms and timing mechanisms but cannot set the clock.
Nov 07, 2011 | Audio Players & Recorders
I have bought jbl on time 200P dock station for ipod with radio but all the freq in radio is odd numbers and i need to change it to even numbers
Sep 05, 2011 | JBL On Time 200iD iPod Dock/Clock Radio...
I have an i-connex ipod docking station model 583258 with clock/alarm and radio but I have been unable to set the clock as I have mislaid the instructions. I am usually pretty good at working these things...
1. Fit the DC power and switch on the appliance by pressing the standby button 2. To set time, press CLOCk button to alternate between 12 and 24 hour format. 3. Press and hold CLOCK button until the set hour flashes on display 4. Adjust time using SKIP/SEARCH 5. Press CLOCK to set the time, same procedure for minute
To set alarm
1. Press AL SET 1/OFF 1 button, then press and hold the same button until the alarm time starts flashing 2. Press SKIP/SEARCH to to set time as above
Jan 17, 2011 | Audio Players & Recorders
How do you set the clock and alarm on the Starlite Next Play Clock Radio with iPod Dock NP105CR
Setting the clock for the Ipod docking station
NP105CR
Press the set button 3 times until all the digits for the main clock are flashing. Press the skip forward and back button for hour and volume up and down for minutes. Press set button once to confirm and exit the setting menu.
866-387-2027 for manual
Jun 23, 2010 | Starlite Next Play Clock Radio with iPod...
I have lost he instructions for my Ministry of Sound hi-fi with docking sysytem and don't know how to tune the dab radio...can anyone help?
plug it and with power on but don't turn the station on, leave it in standby mode. then press and hold mem/set on your remote. then set the hour and press mem/set to move onto the minutes. when done press mem/set again and your time is sorted.
May 31, 2009 | Sony STR-D600SS Shelf System
Ipod cuts out when played through speaker system
i have somewhat of a similar problem with my ipod Touch and my JBL docking station alarm clock thingy. It may just be that the ipod is not compatible on some of the levels that the Igroove is. With my docking station, it wont charge my ipod touch itll only play music
Apr 11, 2009 | Apple iPod nano
Instruction manual for innova docking station
They do not exist. I was not given instructions with mine. Now its only function is an Ipod charger and speaker.
Jan 30, 2009 | Innovative iPod Clock Radio with Dock...
Alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Nov 28, 2008 | Digital Products International Clok Smooth...
JBL on time
No luck finding repair, so have accepted that mini jack into ipod and aux-in socket in on-time will have to do. My daughter is satisfied!!
May 22, 2008 | JBL Audio Players & Recorders
JBL On Time Docking Station for Apple iPod (ONTIMEBLK) Logo
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
