There are multiple blue lines across the display. More lines are appearing every time the machine is turned on. Soon will not be able to read display.
SOURCE: instruction manuals/user guides
Manual for Janome 9000 is available from the Janome site.
http://www.janome.com/documents/File/Man...
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
SOURCE: JANOME MEMORY CRAFT 5700 INSTRUCTION BOOK
Hi, I downloaded (for free) a copy of the Envision 8006 (and 8007 supplement) manual from the Elna website 2 1/2 years ago. The Envision 8007 is the same as the Janome Memory Craft 5700. I can email you a copy of the manual.
SOURCE: WHERE IS THE FUSE FOR THE JANOME MEMORY CRAFT
Remove the top cover by taking the two large screws and the small one under the handle, LHS.
Remove the left side cover. The hidden screw is a 2.5mm allen accessed through the vent.
Lay the machine on its back and remove the four large phillips screws on the bottom and the small screw for the side, paying extreme caution with respect to the embroidery arm.
CAREFULLY move the bottom to the left and out of the way.
Inside the body of the machine you will see a black box held in place by three or torx/slotted screws. Remove the screws and, as you slowly pull the box out MAKE NOTE OF WHICH WIRES PLUG IN WHERE.
SOURCE: janome memory craft 4000 manual online
You can find it here:
http://ifixmachines.com/index.php?page=shop.product_details&product_id=776&option=com_virtuemart&Itemid=54
SOURCE: Instruction manual for Janome memory craft 6000
NO MENUAL BOOK IN URDU,SO CANOT OPRATE PROPERALY AND EASLY.
HI! I BOUGHT JANOME 9000 AND IT DISPLAYS JAPANES LANGUAGE WHICH I DO NOT UNDERSTAND,PLS HOW CAN I RESET IT TO ENGLISH LANGUAGE?
