Microsoft Windows 7 Home Premium Family Pack for PC Logo
A
Anonymous Posted on Jul 21, 2014
How to recover my internet explorer icon on window 7
64 bits
micky dee
Level 3:
  • Microsoft Master 3,015 Answers
  • Posted on Jul 08, 2015
micky dee
Microsoft Master
Level 3:
Answers
3015
Questions
0
Helped
1060289
Points
8762
Start > All programs > Find IE > Right click on the icon > Send to > Desktop create shortcut.
Ronald Thompson
Level 3:
Master:
  • Master 560 Answers
  • Posted on Jul 21, 2014
Ronald Thompson
Master
Level 3:
Master:
Answers
560
Questions
0
Helped
134827
Points
1334
Go to the program section, find the listing and right click.
Press the , "add shortcut" line.
2 Related Answers
Anonymous
  • 39 Answers
  • Posted on Aug 18, 2009
SOURCE: How do I make the 32 bit internet explore my default
Desktop Right Click
Property
Setting
Screen Resolution 1024*758 and 16/32 bit
Set
Install Your Internet Explorer
You Success
Enjoy......
Colin
  • 1584 Answers
  • Posted on Mar 10, 2010
SOURCE: I recently bought a dell laptop. It has Windows
Uninstal itunes / re-install and be careful what you tick.
HOW TO RECOVER INTERNET EXPLORER ICON?
Hi Anonymous,
It is unfortunate that the Internet Explorer Icon is lost. You may want to use the below link and try following the steps mentioned in it to recover the Internet Explorer Icon:
http://bit.ly/1l1cAWK
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Where is my internet explorer
Open Explorer, goto
"C:\Program Files\Internet Explorer\iexplore.exe"
Press with mouse cursor on the icom "right mouse button"
Select "Pin to Start Menu"
I got a new computer i cant see my web icon no more
Assuming you have one of the Microsoft Windows operating systems (Windows 7, Windows Vista, Windows XP, etc.) go to Start -> All Programs -> Internet Explorer.
To add a shortcut to the Start Menu, right click on Internet Explorer icon, and select "Pin to Start Menu".
To add a shortcut to your desktop, right click on Internet Explorer icon, and select "Send to" -> "Desktop (create shortcut)"
3helpful
1helpful
Have lost internet icon on aspire one
If you are using windows xp
click on start once you see internet explorer drag the icon on the desk tp.
if you are using windows vista or windows 7
click n the pearl button ,in the search option type internet explorer,once you see internet explorer icon drag it on the desktop
THAT'S IT!!
Internet explorer is not visible on desktop
Find a Missing Internet Explorer Icon in Windows XP
  • Step 1 Click the "Start" button. Click on "All Programs." Look for an icon called "Internet Explorer." Right-click the icon. Select "Copy" from the menu.
  • Step 2 Find a blank space on your Desktop and right-click on it. Select "Paste" from the menu. You should see a new icon called "Internet Explorer." Double-click it to make sure that it works.
  • Step 3 Open "My Computer" on your Desktop if you were unable to find the Internet Explorer icon in "All Programs." Double-click the "C:" drive. Double-click "Program Files." Open the folder named "Internet Explorer."
  • Step 4 Select the "iexplore.exe" icon and right-click on it. Choose "Create Shortcut" from the menu. Scroll down to the bottom of the window. Right-click the "Shortcut to iexplore.exe" icon. Click "Copy."
  • Step 5 Paste the icon to your Desktop. Open it to make sure it works.
  • Step 6 Click the "Start" button and select "Search" from the menu if you are unable to find the "iexplore.exe" icon in your Program Files folder. Search for "iexplore.exe." Locate the file. Right-click it to create a shortcut. Paste the shortcut to your Desktop.
  • Find a Missing Internet Explorer Icon in Windows Vista
  • Step 1 Click the "Start" button. Select "Run." In the "Run command" box, type "regedit.exe."
  • Step 2 Look for the key ""HKEY_CURRENT_USER." Click twice to open it.
  • Step 3 Navigate to "Software" and open it. Open "Microsoft," "Windows," "CurrentVersion," "Explorer," "HideDesktopIcons" and "NewStartPanel."
  • Step 4 Open the "{871C5380-42A0-1069-A2EA-08002B30309D}" key on the right side of the screen. Change the value to "0" to show the icon on your Desktop.
  • 0helpful
    I have lost part of my toolbar in internet explorer 8, the bit that has the home page icon, Safety, Tools etc. How do I get it back?
    Hello Sir
    kindly follow the below steps , there are few registry edit as well.
    Close all open Internet Explorer and Windows Explorer windows.
    Click Start, and then click Run.
    In the Open box, type regedit, and then click OK.
    Locate and then click the following registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar
    Use one or both of the following steps, as appropriate for your situation:
    For Windows Explorer: In the details pane, locate the Explorer subkey, and then open it. In the details pane, locate the ITBarLayout value. Right-click this value, and then click Delete.
    For Internet Explorer: In the details pane, locate the WebBrowser subkey, and then open it. In the details pane, locate the ITBarLayout value. Right-click this value, and then click Delete.
    On the File menu, click Exit to exit Registry Editor.
    Check whether the problem is fixed.
    if not then follow the below steps
    HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\ShellBrowser
    Which macromedia flash player software support 64bits processor
     Flash player software wont support Windows 64 bit.
    To run flash player in your browser. Follow the steps below,
    • Open C drive. You can find 2 Program Files Folder.
    • Open up Program File(x84)
    • Click on Internet Explorer Folder
    • then Create Shortcut of the internet explorer icon to your desktop.
    • you can use this for any appication and also for Flash Player.
    • This is 32 bit Internet Explorer.
    Hope this Helps, Please Rate My Response! Thanks!
    PREM
    Top Microsoft Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    k24674
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
