Question about Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Free harddrive recovery
Cannot write
  • 1 more comment
  • Syahrial Nur
    Syahrial Nur Jul 22, 2014
    My computer is notebook HP 6120NX and using Win XP Home SP3
  • Syahrial Nur
    Dvd/CD rom can play video or music but cannot write I have tried using CDburnerXP,infrarecorder,isorecorder but cannot detect the drivers. the drivers is sony cd-rw crx835e ,
  • Syahrial Nur
    Syahrial Nur Jul 25, 2014
    I mean that sony cd/dvd rom can't burn it
  • 3 Answers
You can check to see if maybe there is a firmware update for that particular laptop model. Sometime the manufacturer will go threw a third party for there burners. You can check by going to there website as well. I would also uninstall the current drivers and install a current version. Your drivers could be corrupted. Hope this points you in a good direction.
Posted on Sep 03, 2014
Data recovery
There are many freeware and pay data recovery programs available on the web
Try this freeware call smart Data Recovery
http://www.smartpctools.com/recovery/ind...
This is different from other recovery software because it not only recover lost file from harddrive and floppy like most do, but also recover from removable media like flash drive.
http://download.cnet.com/pandora-recovery/3000-2094_4-10694796.html
File recovery has never been easier thanks to Pandora Recovery. The program's wizard-like approach to finding and retrieving lost files will appeal to all users.
http://www.piriform.com/recuva
Accidentally deleted an important file? Lost something important when your computer crashed?
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Sep 28, 2013 | PNY Computers & Internet
My harddrive crashed I need free software to recovery photos
there are many freeware and pay data recovery programs available on the web
hope this helps
Sep 09, 2012 | Dell Computers & Internet
Hitachi harddrive failing
You can recover data from hard drive with data recovery software.Then format the drive toget it fixed.
For data recovery program,here are two of the best Iused.
For Windows: http://www.any-data-recovery.com/index.htm
For Mac: http://www.stellarinfo.com/mac-data-recovery.htm
You can download one of them and scan your hard drive for free to previewwhether your files can be recovered. They will show you the file name, type, dateand of your files and thumbnails for your pictures that it found on yourdrive.
Oct 08, 2011 | Computers & Internet
I have used my 1 terrabite harddrive with macbook. I did not format it for mac. Now I cannot open the harddrive on mac or windows and I have very important info stored. How can I retrieve the info?
It sounds like the partition on your Verbatim drive is damaged but the first thing to do is determine the condition of the drive. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed remotely over the Internet from a boot cd that you download and the best part is they just ask for donations if you are happy with the results: http://FreeDataRecovery.us
Aug 12, 2011 | Verbatim VER95327 USB Hard Drive
Hi, i have a SimpleTech External Harddrive... and it won't open when i plug it into my computer - i have taken it to bestbuy where i had purchased it, and they tried to open it as well - they had no...
Data recovery can be expensive the most expensive recovery labs may charge $2000. But for a 320GB drive you can get the data recovered for much less money.
This guy does data recovery remotely over the internet and works for donations http://FreeDataRecovery.us
Another good low cost option is http://300dollardatarecovery.com
Jul 21, 2011 | SimpleTech Signature Mini 320GB External...
My lacie drive fell off desktop and is not recognized as readable by my Mac. What chance do I have of recovering the data?
Inside that LaCie external harddrive's enclosure is a regular SATA harddrive.
The kind that fits in a desktop computer (3.5 inches in width), or laptop. (2.5 inches across in width)
Open the external enclosure (Case) of the LaCie, remove the harddrive, and install it into a suitable external enclosure.
(Laptop size, or desktop size)
The external enclosure has a USB cable also. Just plug it into any available USB port on your desktop computer.
Do I know for a fact that the harddrive is okay, and this will fix the problem?
No sir/maam I do not.
But IMHO this is the first diagnostic method to use.
IF the harddrive is a desktop sized harddrive, it could be installed in your desktop computer as a Slave drive.
However the above method is so much easier, and it allows your harddrive to be an external harddrive once more.
Inside the external enclosure of the LaCie external harddrive, is a small circuit board that the Harddrive plugs into.
It is this small circuit board that receives the damage in most cases.
If the problem is the Harddrive itself, a professional data recovery shop will;
A) Try a new, or good used harddrive circuit board.
Check to see if the harddrive's circuit board received the damage.
B) If the circuit board proves to be good then the next step is to remove the Platters inside.
The room used is a Clean Room.
A room that is 99.9 percent dust free. (In most cases)
The Platters are installed into the case of a compatible harddrive, that has the Platters removed.
Then as much information as possible is copied off.
There are other methods data recovery specialists use also.
[A Harddrive is built in a Clean Room. 99.9 percent dust free. The technicians wear a Clean Suit, that resembles what a doctor would wear in an operating room.
They enter the work area after going through a corridor, fitted with air jets at various levels.
If a harddrive is opened up in a room that is not a Clean Room, the harddrive's 'life expectency' drops to a day, or a few hours. The dust 'kills' them ]
http://computer.howstuffworks.com/hard-disk.htm
http://www.youtube.com/watch?v=gpY8c7lT_7k&feature=related
http://www.youtube.com/watch?v=ax390l2A-AY
Observe the other videos also.
Examples of both a SATA 2.5 external enclosure, and a SATA 3.5 SATA enclosure,
(The Harddrive's width is measured in inches. (2-1/2 inches for a laptop drive, 3-1/2 inches for a desktop drive)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
SATA 3.5 external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4421576&CatId=2780
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 02, 2011 | LaCie Hard Disk design by Neil Poulton...
My one tuch recovery not working
Most one touch recovery feature are preloaded to the harddrive and if this feature is not working anymore its either you ask for recovery disc from your manufacturer for your computer or have it sent back to the manufacturer so that they can reimage the harddrive.
May 15, 2010 | Belkin Computers & Internet
In bios hdd is not displaying some sound used to comes like ketyc ketyc what is the problem of it.
Well the symptom in your laptop indicates that the HDD of your laptop is gone, and you need a new HDD in place of old. No other region seems, because this sound indicates all............
Please feel free to post more questions........
Good Luck!!
Thanks
Dec 22, 2009 | Acer Aspire 3000 Notebook
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
Sony CRX835E CD-RW/DVD-ROM (Combo) Burner Logo
50 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
