It's good that you have cleaned the beater bar and the end of it, as this is often the cause of the problem when the beater bar stops spinning.
If cleaning the beater bar and end of it did not resolve the issue, there are a few other things you can try:
- Check the belt: The belt connects the motor to the beater bar and if it is damaged or stretched, it can cause the beater bar to stop spinning. To check the belt, turn the vacuum over and locate the belt. If it is damaged or stretched, you will need to replace it.
- Check for debris in the brush roll housing: Debris can sometimes get stuck in the brush roll housing and cause the beater bar to stop spinning. To check for debris, remove the brush roll and look for any foreign objects that may be stuck in there.
- Check for a clog in the hose or the suction path: A clog in the hose or suction path can also cause the beater bar to stop spinning. To check for a clog, remove the hose and use a flashlight to look for any blockages. If you find a clog, use a broom handle or similar object to carefully remove it.
If these troubleshooting steps do not resolve the issue, it is possible that there is a problem with the motor or another internal component of the vacuum. In this case, it may be necessary to have a professional repair it.
