115101: Ramsey Badger Series Winches Logo
A
Anonymous Posted on Jul 20, 2014
What is the wiring diagram for winch remote
Plug pulled from wires
Timllfixit
Level 3:
  • Ramsey Winch Master 2,210 Answers
  • Posted on Jul 30, 2014
Timllfixit
Ramsey Winch Master
Level 3:
Answers
2210
Questions
0
Helped
484410
Points
5787
Ramsey website shows Badger wiring diagram for solenoid hookup etc but not plug. Shouldn't take a good DIY mech or auto electrician too long to work out which wire goes where especially if they loosen the socket it plugs into which should reveal which wires go to where on the solenoid block. Basically that's all they do, there's a supply side, a ground wire and all the hand control does is switch the supply to the solenoid for forward and reverse. From memory there's only 4 wires? Supply to hand control,1 wire to one sol, 1 wire to other sol, 1 ground wire. Supply could be red, ground is usually black, fwd / rev will be 2 other colours. Look at the socket to see match up?
I have a 12000 pound winch theres no control box or remote not sure of brand looking at the winch on the right hand side theres a control handle for in,out and nutrail,on the left hand side theres
Seems that you are correct about the colors. In order to figure out which wire is responsible for which operation (or combination of wires actually), you should have an electrical diagram to guide you. My guess is that black is the ground, red is for pulling, and yellow is for reverse direction. The 12 volts from the electrical system are directed to one of those two leads. That is only a guess on my part.
Jan 02, 2019 • Dryers
How do i rewire a warn 12v 8000lb winch
There are lots of links on the internet to wiring diagrams; just make sure they match the winch you have
warn 8000 lb winch wiring diagram Google Search
1helpful
2answers
My winch don't move it all?
if you can use the winch manually by pressing buttons on the winch then the problem will be in either the remote unit(Battery in back to front) or the receiver in the winch
I need a winch wiring diagram
The third wire should be the extra ground wire and is usually grounded to the metal body of the device.
Wiring diagram for pierce winch model ps656-d2
We have no diagrams, we only offer advice.
Try the search engine of your computer, listing the information you have already given us.
There should be a dealer pop-up that will help you.
God bless your efforts.
Wire diagram for 9' ATV Rocker Winch Handle Bar Mount Remote Control Thu to the winch
Here's the owner's manual - it includes wiring & installation information:
http://mediacdn.shopatron.com/media/mfg/4377/media_document/4398/10991.pdf
If you're looking for information that is not provided in the manual, you should contact Superwinch directly:
In the USA:
Superwinch, Inc.
Winch Drive
Putnam, CT 06260
U.S.A.
Tel: (860) 928-7787
Fax: (860) 963-0811
e-mail: [email protected]
Elsewhere:
Superwinch, Inc.
Unit D, Union Mine Road
Pitts Cleave Ind Est
Tavistock, Devon
PL19 OPW England
Tel: 44 (0) 1822 619222
Fax: 44 (0) 1822 615204
I hope this helps & good luck!
8helpful
Wiring up super winch
I am wiring a Superwinch 4500 to my Yamaha Rhino.
Problem the two red wires go to the key switch.
Do they just splice into the 12 wire ?
Top Ramsey Winch Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Ramsey Winch Vehicle Part and Accessory Expert? Answer questions, earn points and help others
