Moss Fet Transistors Failure.
When an UPS works too Much time power line disconnect always the UPS only works for a while. too much time working with the Batteries inside makes the power converting transistors overheating and failure.
Check Internal Fuses, inside the UPs there is an automotive Fuses(30 Amps) plug tipe like in cars.
if the fuses are OK .........................then check it by a Technician.
Check it by a Qualified Technician and check the Mossfets.
If you have NOT changed the default password, that is: Manufacturer
Model
Protocol
Username
Password
BELKIN
F5D6130
SNMP
(none)
MiniAP
BELKIN
F5D7150 Rev. FB
MULTI
n/a
admin
BELKIN
F5D8233-4
HTTP
(blank)
(blank)
BELKIN
F5D7231
HTTP
admin
(blank)
If you have changed it, just reset the router and use above passwords.
Check on the underside of the unit, there may be a sticker with your SSID on it. If you need to you can also reset the password back to the factory default by holding down the reset button. You can also download the instruction manual from here:
KVM are not the most reliable and will fail sometimes. The quickest way to get it back is to plug into a different USB port for the one that is active.
Surge protector, minimizes voltage spikes or burst that could damage your electronics. You may not see it doing anything but it does. It clips those voltages to the right rating befrore letting them in to your system.
