I have checked all connections unplugged and re-plugged all devices including broadband box from comcast. had to bypass at this time to log on. Yet when I put it back in line is says that the router is connected to the network. Try to sign on but no luck til I bypass router again. Has been working fine until I had a comcast issue now won't work.
NOTE: The image may vary depending on the computer and modem you're using.
Once an active Internet connection is established through the modem,
connect the modem and the computer to the router by following the
instructions below.
Connecting the Devices Together
After ensuring that you have an active Internet connection, connect
the modem to the router's Internet port and the computer to any of the
four Ethernet ports. For instructions, click here.
After connecting the devices, check the LEDs by following the instructions below.
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the
connection. After connecting the broadband modem to the WAN or Internet
port, the computer to an available numbered port and powering on the
router check the lights on the front panel of the router. For
After checking the router's LEDs, configure the router for cable Internet. For instructions, follow the steps below.
Configuring a Linksys Router for a Cable Connection
For Telstra Cable
internet users, please contact Telstra to confirm if your internet
connection is using DHCP or HB (Heart Beat) signal. There should be no
other machine running HB client upon doing this procedure.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using Mac to access the router's web-based setup page, click here. If you forgot your IP address, click here. If you forgot your router's password, click here.
Step 2:
When the router's web-based setup page appears, click the drop-down arrow under the Internet Connection Type field and select Automatic Configuration - DHCP.
(a) If you are NOT using Telstra HB, proceed with DHCP setup.
NOTE: If you are a Telstra Cable internet user and you're using WRT120N, WRT160N v1, WRT320N or WRT610N, please select Telstra Cable.
(b) If you are using Telstra Cable,
proceed with the following setup. Obtain your user name and password
from Telstra. Please disable any HB client that might have been
previously running on the PC after the router is configured.
Step 3:
Click .
Step 4:
Click MAC Address Clone.
Step 5:
Select Enabled and click Clone My PC's MAC.
Step 6:
Click .
Step 7:
Click Status. Check the value of the Internet IP Address. If the Internet IP Address
has numbers, this means the router has been properly configured. You
should now be able to access the Internet. If you're not online, perform
a power cycle to synchronize the router with the modem. For
NOTE: If the Internet IP Address is all zeroes (0.0.0.0) click first then click . If the Internet IP Address is still all zeroes (0.0.0.0) perform a power cycle. For instructions, click here.
If the IP Address starts with 192.168.1.xxx
or if it has the same first three numbers (octets) as the router's IP
address, change the router's LAN IP address to a different LAN segment.
Once the router is configured, perform a power cycle. For instructions, follow the steps below.
Power Cycling
Step 1:
Shutdown the computer.
Step 2:
Unplug the router's power cable.
Step 3:
Unplug the Broadband modem's power cable and wait for 30 seconds.
Step 4:
Plug in the Broadband modem's power cable and wait for its lights to appear stable.
Step 5:
Plug in the router's power cable once the modem's lights appear stable.
Step 6:
Power on the computer on and test the Internet connection.
NOTE: If you're not online after performing this procedure, you may need to upgrade the firmware of the router.
belkin is giving signal but not allowing internet acces.....everything connected , broadband and router properly connected to modem and ect. but i cant get a network to open up!?
used router fine then one day when tried to log on error says unable to iniatialize modem after bypassing router finally can log on again but can not use router
was using router then one day error says unable to inialize modem can use if by pass router and connect ethernet
