The mixture of the echo gas n oil leaf blower
I currently have 2 Stihl BR600's for the lawncare side of my business. They work really well and I'm very happy with them. The next blower will be a Maruyama , simply because I want to experience it after hearing and reading many positive reviews
The Best Backpack Leaf Blowers Aug 2018 Guru Reviews Ratings
50 to 1 (about 2.5 oz. per gallon)
Most new machines are 50:1
SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
SOURCE: gas is leaking from the leaf blower.
Unless the tank has been cracked, it has to be one of the following: Broken lines, split primer bulb, unsealed fuel cap, bowl gasket of carb. I would start with the lines and bulb since they are the ones usually at fault..Good luck...Lee
SOURCE: need to know gas oil
50:1
Check this site out:
www.modernoils.com/ATO_Saber_Outboard_100to1_PreMix_Oil.html
Jim
SOURCE: What is the oil and gas mixture ratio for a gas
per http://www.echo-usa.com/faqs/ the ratio is 50:1, there is a chart at the site shows how to mix it together.
