the only things is the TIMER: CAN BE FAULTY, maybe is stuck, not completely the cycle. Clean the contact with special spray, loose the wires, replace burn wires, or break wires.
Hello there,
The reason your fridge is freezing up is simply because there is a problem with the defrost unit of the refrigerator. The defrost thermostat simply could have gone bad and therefore is not getting the defrost heater to start work.
Have the defrost thermostat tested and replaced once found faulty.
Hope this was of help to you.
All the best
Elect_Comp
Either the thermostat is set to high or you need to replace the thermostat.adjust it to 1/2 way position position and if temp is to cold and it doesnt want to switch off, it means the thermostat is faulty.
Your thermostat should not remain closed if the water temperature is above 85. The best way to find out if the thermostat needs replacing is to remove it (when the engine is cool), place it in a pot of water with a candy thermometer, and boil the water. You will see the thermostat open at some point. If it opens before 80-85, replace the thermostat.
if your refrigerator is in warranty than contact your service authority......or if you had purchased it by your own than ...... my friend! the thermostart does'nt have any warranty
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair
shop diagnosed a thermostat problem. I have replaced the thermostat,
Now the freezer freezes without any problems but the fridge does not go
cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is too warm. Freezer temperature is satisfactory. 1. Fresh Food control is set too warm. 2. Set fresh food control to a colder setting. Allow 24 hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back! This would also cause the compressor to run none stop trying to cool the fridge! So check your air vents in the freezer. I'll bet you did not know they were there ! Most of us never notice! Hope this works for you. Please let me know that one of these solutions worked for you! or if you have any questions. Thank You, huuum Please remember to leave a rating!
i have candy fridge freezer which the thermostat is on high setting but not cold as it should be. There is build up of ice around thermostat at the back of fridge inside. What is needed to repair?. Any ideas? Cheers!
