Primary v-belt , mower , on gth2548 keeps tearing/chunking out
I have a CTH2542 which has a 42" cutting deck. I bought this from new and it's now aprox 8 mths old. I observed slippage problems with the machine after about 3 months, and being a diesel mechanic myself, dropped the cutting deck off and checked the drive belt. It appeared to be an 'A' section belt which means it should be of 1/2" (12.7mm) section. Measurement revealed it had worn 1mm and was bottoming out on the drive pulley at the motor. Once any vee belt (or pulley for that matter) wears to this point it must be replaced as it WILL NOT grip the sheaves of the pulley. I had my local service agent look at it, but they say they could find nothing wrong. I investigated the problem further and to my surprise, I discovered the swinging (spring loaded) belt tensioner has been positioned on the loaded side of the vee belt. Therefore the more load that's placed on the drive, the more the tensioner is pushed aside, and the looser the drive belt becomes. I have re-jigged the drive setup on my machine (it was suprising easy once I'd figured out what to do). Now, if I **** the bull bar of the machine against my Ford tractor tyre, and load the hydraulic transmission, the rear wheels will actually spin - it wouldn't do that before. The reason I investigated this problem so thoroughly was because I went to buy a replacement vee belt for the machine and was told 'Husqvana tractors for some reason munch up standard vee belts - you must use the genuine belt which is kevlar based'
regards
Mike Clarke
Hamilton
New Zealand
