Brookstone Softtouch Acuvibe Body Massager Logo
A
Andres Ortiz Posted on Jul 19, 2014
My Model N0:D3-15A Transformer needs replacement
I need a to order or buy a replacement charger.
Gab C
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 09, 2015
Gab C
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
969
Points
  • I have not been able to find a replacement transformer anywhere! I have been looking online and in stores for an entire week. This is the second time, I have blown a transformer. I believe we have to purchase a new unit once again.
I need color code for wires going to selector switch with 8 pins coming from transformer. Model se-82-6
hi
find all 8 pins day-gram for battery chargers
https://www.google.com/search?q=I+need+color+code+for+wire+going+to+selector+switch+with+8+pins+coming+from+transformer.+Model+se-82-6+battery+charger&tbm=isch&ved=2ahUKEwiswdPzyKP0AhXWALcAHWTFAKUQ2-cCegQIABAA&oq=I+need+color+code+for+wire+going+to+selector+switch+with+8+pins+coming+from+transformer.+Model+se-82-6+battery+charger&gs_lcp=CgNpbWcQA1DmU1i_hQFgqIoBaABwAHgAgAEAiAEAkgEAmAEAoAEBqgELZ3dzLXdpei1pbWfAAQE&sclient=img&ei=ZiWXYaz2NNaB3LUP5IqDqAo&bih=657&biw=1366#imgrc=5BVOX4JophqPOM
1helpful
Input 120v 60hz 25w output 3VDC 1500 mA I need a new transformer for an Acuvibe plug in class 2 Model D3-15A
Buy a generic multi voltage charger or any cell phone charger (they run on 3 volts) from a local electronics store or cell phone accessory shop, then solder and shrink tube your charging adapter onto the leak on the charger. You most likely can't buy the original charger. When you install the old charger end on the new charger end that plugs into your device make sure you pay attention to the polarity, one lead is market with a white stripe, one with none.
DRIVEWAY ALERT MONITOR
Tries to reassemble the plug and rescrews tighten all the screws or supper glue it together again.If the power transformer charger it is a standard A/C plugin chargers,tries places like Walmart,Best Buy,Radio Shack or online shopping too like Amazon.com,eBay.com and the product manufacture too can buy the original transformer charger or a clone one should work too, if charger it have the same A/C input and output of the transformer charger plug in power like Amp,Voltages lable that in the transformer plug in part of the charger.
4helpful
5answers
The Bacini Acoustica will not charge. It works only when the charger is plugged in. Could the battery be "dead"? If dead, what type do I need to replace?
It requires a 12V 7.2ah battery F1 terminal. Its located on the bottom of the tower just under the charger input. You need a phillips screwdriver to remove the cover plate which has 6 screws. If you own this Bacini Acoustica Tower Speaker, please publish the wall charger information found on the back of the charger. I need to replace that.
2answers
Weak light
If the charge lite comes on when charging it means your transformer is still good. Replace the battery.
If you get no charge light transformer is bad, if this is the case (personally) i would replace the charger & battery for that peace of mind.
GGBMDB
12helpful
5answers
Modifying the DC18RA from 110V to 220v
Hi there the solution for how to mod a DC18RA charger can be found here. The "how to" comes with pictures and descriptions and it should be easy to follow, and best of all it works :)
Top Brookstone Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Brookstone Health and Beauty Expert? Answer questions, earn points and help others
