The camera turns off... I called the customer service and they said it was the sd cards. Replaced them and restarted the camera and it still does it.
SOURCE: camera screen said SD card is locked when I installed an SD card
#1) On my camera if there was a picture that got stored in the internal memory it would not reconize the sd card nor store the pictures on the sd card. I would have to take the sd card out and delete the pictures in the internal memory and then reinsert the sd card.
#2) Some how or other the files that were on the sd card would get scrambled on the sd card when I would try to erase them. I would have to reformat the sd card back to a "fat" format before it would work again.
SOURCE: Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
