Good morning, afternoon, evening or night; whatever time of day you receive this. You want to know how much to fix the touch screen and where to fix it? I want this solution to
benefit you as much as possible. Having to pay for someone to fix your
iPod touch screen should be your last result. I'm tell you some options you can try that may save you a few dollars and having someone to fix the
iPod touch screen. I don't if this is the problem, but the touch screen may be locked. Automatically, the
iPod touch locks when there has been no activity for a certain amount of time. To unlock the touch screen, press and hold the Home button or the On/Off/Sleep/Wake button which is located at the top of your device, and then drag the slider. If you want to set the amount of time before Auto-Lock activates, press Settings, General, Auto-Lock; then set your preferred time. If that doesn't fix the problem, you can try a system reset. To do this, press and hold the Home and On/Off/Sleep/Wake buttons together for approximately 10 seconds until the Apple logo appears on your screen. If this doesn't work, you can take your
iPod Touch to your local Apple Retail store and have an Apple technician work on it for you. There will be a fee for diagnostic services. You can also contact Apple Technical Support or
Online Service Assistant. For more contact information, go to this website (
http://www.apple.com/support/contact/). I hope the problem is just a screen lock up and if you have to get a repair or replacement, it won't burn a hole in your pocket. Thank you for choosing
FixYa as your one-stop solution spot for your problems and requests. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
