Getting power from house outlet? check terminal block with multimeter for voltage? then check thermal fuse. door switch, belt tensioner motor switch etc
My Samsung flashes panel lights in a certain sequence to announce problems but sound like yours is dead.
How did you confirm power to the unit? If you plugged a lamp into the receptacle, then re-plugged the Samsung, you essentially did a "hard reboot/reset", so I won't suggest that.
has a blown inner fuse or a open thermo (under the oven cavity ceiling or on the magnetron). if it's the main fuse out, you probably have a failed component.
In order to get power on it, you have to have Power cable also plugged in. Once power cable is plugged in, now connect to PC using USB, and it should power up and computer should recongnize it.
