Every iPad should be capable of sending email. You first have to setup the account, in settings, then email, then add new account.
While entering a new account, you have to fill in all settings correct, so you need to know it it is a POP or SMTP server, you must fill in the complete and correct e-mailadres and server name and the correct password. if filled in and you press next, the program will check the validity of the address. Only if the address exists and the password is correct it will tag everything green. Then you can use the mail address. It must be an existing mail address. You can't create new addresses in that part.
I'm not sure if you are running the iPad on a G3 or G4 network from BT, because that firm can try to block other mail, to save bandwidth, but I don't believe that.
You should be able to setup the BT account. If you keep having trouble setting up the BT account, visit a bt store and ask them to setup your mail address
SOURCE: yahoo mail id not receive/ send the mail
if its truly blocked, you are on a blacklist and Yahoo! Customer Support is the only one who can help. Most likely the problem is just a temporary issue with your id, and you should try 30 min later.
SOURCE: cant find my mail [email protected]
If another user logged in to his email from your computer, then press the Sign Out link at the top and then enter your own email.
Regards,
nicolasiac
SOURCE: how do I send all
Open Yahoo Email, click on "Contacts", on the right you will see "Share My Info", click on that, then send message to all contacts.
SOURCE: NEWlaptop,want to set up adresss
If you have already made an address book in any other email ID of yours (e.g. Gmail) you can import all the contacts directly to your Yahoo ID.
If you have set up a contact list in Windows, that can come in handy too, if you export it to a .csv file and import in Yahoo mail.
If you have not set up any address book so far in any ID, then its a manual task for you to add each entry individually.
