Sony PlayStation 3 40GB System Logo
A
Anonymous Posted on Jul 18, 2014
Playstation 3 got hot and stop working ,it will not turn on what is the problem? Also how do i get disk out?
Unit will not turn on at all,so how do I get disk out?
Matt Weaver
Level 3:
Master:
  • Sony Master 665 Answers
  • Posted on Jul 19, 2014
Matt Weaver
Sony Master
Level 3:
Master:
Answers
665
Questions
5
Helped
803630
Points
1543
I haven't heard of a PS3 getting so hot it bricks. If it won't turn on at all, you have no choice but to open it up to remove the disk. All of the "bricked" PS3's I have ever heard of, only has 1 solution......Buy a new one. There is no way to fix it if it's bricked. If you are not familiar with the term, "Bricked" means the system is completely unresponsive. No power or anything. I will hook you up with a link how to remove a disk from the PS3 with no power.
PS3PHAT 60GB CECHC02 How to remove disc manually reset the Blu Ray...
4 Related Answers
A
Anonymous
  • Posted on Jun 13, 2008
SOURCE: playstation 3 stop reading disks
Ihave a PS3 GOT IT FOR CHRISTMAS HAVENT HAD A PROBLEM UNTIL TODAY IVE NEVER HAD IT CONNECTED TO A INTERNET IS THIS MACHINE A PIECE OF **** IT COST ENOUGH I CALLED THE 1800 NUMBER TALKED TO A TECHNICIAN FOR A HOUR STILL DIDNT WORK IT WAS OH WELL
Anonymous
  • 207 Answers
  • Posted on Jun 17, 2008
SOURCE: playstation3
First try going to the store and buying a cd lense cleaner.. it just may be dirty..
I have opened tons of ps3's and you would not believe the dust inside of them..
IF thats a no go
then
Call sony asap, they will fix it as long as the seal on the side is intact.. it costs 150-175$ but a drive on ebay costs 130 plus s/h.
Then you have to put it in yourself.
Sony will give you a 90 warrenty on the system they send you.. it may be more not sure.
Anonymous
  • 22 Answers
  • Posted on Jul 30, 2009
SOURCE: Playstation 3 unit stopped working and will not
To send it in for sony repair:
http://eservice.sony.com/webrma/web/index.do
Anonymous
  • 281 Answers
  • Posted on Feb 12, 2010
SOURCE: My playstation 3 stopped working and it has a
If it blinks a red light this is known as the yellow light of death(ironic i know). This is caused when the unit overheats causing the solder on the board to melt and bridge. Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Why does my Playstation rejects game disks?
Clean the laser. Either open the unit, and clean the lens with a q tip and rubbing alcohol, or get a CD cleaner kit. If that doesn't work, you'll need a lens replacement like I did on mine eventually.
Playstation 3 will not turn on at all i have a disk i like to remove
Depending on the model of PS3, if you are getting no power, then the only way to get the game out is to crack open the system and manually remove it. There are several vids on youtube of how to do this.
Cd rom in playstation 3 console stopped reading
Your Bluray disk drive has stopped working. If you are still under warrenty, then you can send it in for free. If not, it's going to cost you $105.00 USD for the repair. Contact SONY online for a service repair. They will ship it for free.
2helpful
I do not know what to do says Please insert PlayStation or PlayStation 2 format disc. Please read it if you write to me with otgovor.A'm desperate.
if the disk is a Blueback, most modern PS2 consoles won't touch it. bluebacked disks still have their data stored in CD format rather than in a Data DVD
to play a Blueback
1. turn on the unit without a disk in
2. press Triangle on "browser"
3. scroll up to the top item and press triangle again
4. turn "Diagnostic Mode" ON
5. back out with circle, and start the browser
6. put your disk in with the browser on. is should read the disk
some disks will still cause the red screen (like cheat devices) occasionally
My playstation wont how tha disk wen i put
question did you update the firmware for the PlayStation? if so their is a potential that you patched the unit and can not longer play some files this way. a precaution taken by psp already to stop downloads of home brew and emulated media.
Hi my playstation has stopped reading any disk
This is a very common problem on the Ps3 and is the first sign that your Bluray drive is malfunctioning.
Sometimes you can resolve it by gently cleaning the lens with a Q-Tip and isopropyl alcohol but most often the lens itself will need replacing.
I have included this excellent walk-through on how you can do this yourself.
Please be sure the console is disconnected from the mains supply before carrying out any of this type of work.
http://www.supermodchips.com.au/pages.php?pageid=36
Otherwise the unit will have to be returned to Sony who generally replace the whole drive unit including the lens. Cost from Sony is $150 to make the repair.
Thanks for using FixYa
My playstation 3 fan runs constantly and don't seem to stop unless the power is off.
Hi my name is Juan and I am here to help you on this the fan on this unit is allways on especailly that ou have the 60Gb the ps3 with the 80Gb and 60Gb models they do get verry hot and for this reason the fan won't stop it may even increase speed as heat builds up if the fan on those 2 units that I mention stop working for only 15 seconds belive me the next thing it can happend is playstation will shuft down immediately and it would not start the next time so don't worry for the fan try to make sure you have a good clearance around the ps3 to keep it cool
Playstation 3 stop reading disks
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
