Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
A
Anonymous Posted on Jul 17, 2014
Idylis dehumidifier how to hook up continous run
Idylis dehumidifiers. Any recalls?
U can find out here: https://www.cpsc.gov/Recalls/2017/Gree-Reannounces-Dehumidifier-Recall-Following-450-Fires-and-19-Million-in-Property-Damageb
IDYLIS 052605 dehumidifier will not shut off when the desired humidity level is reached The machine just keeps running.
well does the unit continue to make water in bucket, the reason i ask is that some units have an air circ fan that runs all the time reguardless of setting this is how its designed
Idylis dehumidifier 0526011 will not shut off even when is reaches it humidity level. How can I get it to shut off. The compressor stops but the fan keeps running.
this is a newer feature that a lot of units do now this is called air circulation mode !! try running on low it's not so noisy then
2helpful
2answers
Idylis 0526011 does not work
SET IT TO LOWER SETTING
Wont run through attached hose
my unit runs but does not de humidify
AFTER RUNNING CONTINOUSLY, THERE IS NO WATER IN THE BUCKET
What is the dry bulb temp in the room? what is the wet bulb temp in the room? what are you working in temp (in room)
Top Whirlpool Dehumidifiers Experts
ZJ Limited
ZJ Limited
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
