Pelco Qd104c Color  Quad Video Processor - In Box Logo
A
Anonymous Posted on Jul 17, 2014
Why does my color quad processor show images in black and white?
Jerry Kramer
Level 3:
  • Pelco Master 3,933 Answers
  • Posted on Jul 20, 2014
Jerry Kramer
Pelco Master
Level 3:
Answers
3933
Questions
Helped
881391
Points
12076
Without more information to go on I would say that it is in low light condition. If this is equipped with night vision that it records in black and white in low light situations. The recording feature on the DVR may also be the cause. Make sure you are set to record in color.
1helpful
3answers
My sansui tv started showing in black and white, i have tried everything to fix it but its not changing and it only shows colour when a vga cable is connected.what should i do.
This happens because of the color decoder in the TV. A TV color decoder has a switch that makes the TV image black and white when the received signal does not have sufficient power. Your TV color decoder switch remains in the black and white position (the TV receives weak signal or the TV color decoder is damaged).
Replace the TV antenna, try an antenna amplifier or a digital receiver before the TV.
tip
5 More Black & White Photography Tips
<b>Black & white </b>photography is one of the most interesting and inspiring aspects of this art form we call our hobby and passion. It's raw & refined, natural and unusual, bold and subtle, mysterious and open, emotional and indifferent, simple and complex, black & white & everything in between. The monochrome image has been practicing photography since the beginning, but what began as the only way to capture images is turned into something much deeper.<br /> 1. PRACTICE PRACTICE PRACTICE An experienced black & white photographer can see the world without color. They've trained their mind to pick up contrast and tone while blocking the distraction of colors. This isn't a skill that you can pick up in a short amount of time; it's something that comes naturally in time. I can't say that I'm gifted enough to have monochrome vision, but I have been able to notice certain scenes and subjects that would lend themselves to black & white.<br /><br /> One way to help train your brain is to make a conscious effort - in other words, practice. Trevor carpenter gave us the perfect example when he started his October Challenge. Basically, he decided to limit his photography to black & white for an entire month. This gave him a chance to experiment with the medium and learn from his own work, and in his project recap he states "I have found, especially in recent days, that as I'm shooting and conceiving a shot, I see the potential impact of the composition in black & white."<br /> Zig Zag<span></span><br /><br /> 2. FOCUS ON CONTRAST Black & white photography is about the black, the white, and all the tones in between. The human eye is built to pick up two things: light intensity and color. When you remove the color, your eyes become more sensitive to the light intensity. We naturally pick out areas of contrast - it's how we distinguish one thing from another. As a black & white photographer, your main objective is to make your point with shades of gray. Use contrast to show your onlookers what's important and what's not. Seek out scenes that naturally show signs of high contrast, and your black & white photos will be more compelling right from the start.<br />When post-processing a black & white image, the use of Photoshop techniques like levels, curves, and layer blends give you a wide variety of output options. In addition to these things, burning and dodging are highly effective methods of improving contrast. They work so well because they allow you to focus the edit on a localized portion of the image without affecting the surrounding areas<br /> 3. FOCUS ON TEXTURE Texture is really just a form of contrast, but it is perceived quite differently. If you think about it, texture is the regular or irregular pattern of shadows and highlights at various intensities. Black & white photos really lend themselves to texture because color generally add another layer of complexity, thus masking most subtle textures. Look for areas of interesting texture that can be photographed by zeroing in on specific surfaces and examining them for signs of patterned contrast.<br /><br /> The choices you make in post-processing can really make a difference in the texture too. During the black & white conversion, you can usually pull texture out of otherwise smooth surfaces based on your choice of conversion methods. In digital photos, blues and reds generally contain more noise than greens, so tools like the channel mixer and the black & white adjustment layer in Photoshop can really accentuate those embedded textures.<br /><br /> 4. CAPTURE IN COLOR This is mainly aimed at digital photographers... If your camera gives you the option of shooting in color or black & white, NEVER shoot in black & white. The camera is really capturing color, then converting to black & white. Photo editing software can do a much better job at the conversion, and you'll have more flexibility on the output of the final image. It's really amazing how different a photo can look solely based on the post-processing, so it's best not to limit yourself before the photo even makes it out of the camera<br /><br /> The one exception to this rule is if you wanted to use the black & white capture to give you a preview of what the scene might look like as a monochrome image. It may help you identify good black & white scenes more immediately, but once you find your shot switch back over to color capture and shoot it again.<br /> Under the Weather<br /><br /> 5. USE COLOR FILTERS Black & white film photographers make use of color filters to change the captured tones in their photographs. Ever see those monochrome images with dark skies and puffy white clouds? That's not natural; it requires the use of color filtering to produce the desired effect.<br /><br /> Using an actual color filter with a digital camera is perfectly acceptable and it has its merits, but it's not completely necessary. Software like Photoshop has the ability to apply non-destructive color filters. It also has the ability to produce the same results as a color filter during the black & white conversion. For those of you using Photoshop CS3, you'll see that the black & white adjustment dialog has several preset filters that can be applied and modified to suit the photo.<br /><br />
on Oct 28, 2010 • Cameras
Want to print black and white. How?
Setting the font type color in a Microsoft Office Word document to black will ensure that the document prints the text in black. However, if there are images, graphics or photographs within the document, they will more than likely print in color or hued colors similar to black. To ensure that the entire document prints solely in black ink, you must set the color settings on your individual printer to black-and-white
Instructions:
1.Click "File" and then "Print." To open the print dialogue box using keyboard commands, press "CTRL" and "P" simultaneously.
2.Select the printer you are using at the top of the dialogue box under "Printer" and "Name."
3.Click the "Properties" button next to the selected printer. The dialogue box that appears is different for all users, as it depends on the type of printer being used.
4.Click on a tab, button or selection box indicating "Color." Most options include high-quality color, grayscale and black cartridge only. Choosing grayscale will print the document using various shades of gray and other tones such as blue or green that match the actual hues in the document visible on the screen. A photo or picture that may look black or gray could actually have blue undertones. To print purely in black and white with no undertones, you must select either "black cartridge" or "black and white only."
5.Select "OK" to return to the Microsoft Word printer dialogue box. Press the "Print" button to print the black-and-white document.
I hope you find it very helpful. Thanks.
3helpful
2answers
My dvd's play in black & white. cant get any color in pitures.
There are three types of display settings. 1 PAL, 2, NTSC and 3, Auto.
The pal and auto makes a display show color while the NTSC allow a display show in black and white but sometimes NTSC also shows color. It is possible that the display format on the movie is NTSC.
To fix this problem, play the movie that shows black and white. When the movie shows in black and white, press PAL/NTSC or P/N on the remote control and it should display in color.
Or Go to the player menu, check video or display setting, change it to Auto.
Problem should be fixed because that's where it lies....
But if it doesn't solve the problem, please let me know so that I may direct you further on what next to do.
I hope you understand the above.
Good luck.
2answers
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Epson Stylus Photo 870 only prints black and white
WHen your p;;rinter name comes up, check the printing p;references. You have "P:rint colors as black & white" checked. Un check it. It is in the printer dialog box, not PSP.
2answers
My projector only shows black and white images
probably you are facing with an NTSC signal and a PAL source or vica versa
try to check with a regular tv or with a different source
Printer shows no errors
Is that problem just for that color black? sounds like you might have a bad image unit or developer. You can start out by switching the image units.. switch the Cyan image unit to the Black and the Black back to the Cyan. Print out a solid color page on the trouble shooting menu. If the Cyan prints out bad you have a bad image unit . If Black still comes out splattered then it might be the developer. We always call this company called www.Iteminc.com for support and parts instead of xerox. They have good techninicians. Almost all my answer have come from here. well good luck
Scanned Items or Copies all print in Solid Black
I assume that you mean color images are being produced in black and white. If that's the case, there's a document on the HP web site that shows you what to look for and provides solutions:
Color Image Prints in Black and White
Good luck.
Only black and white!
I have the same problem. I instaled the driver with lot of problems but I made it work. Only in (black and red).
Who can help us
Top Pelco Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Pelco Home Security Expert? Answer questions, earn points and help others
