Kirby G5 Bagged Upright Vacuum Logo
Posted on Nov 07, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kirby G5 - Stopped
Hi there, please help!
The kirby was being used when a noise like Boof !!!! was heard, the front light went off and there was a smell of burning. It was then switched off and back on again, the light did not work, but the motor seemed to try to work then stopped. Changed the fuse, did not work, I am going to change the bulb when I get one. Could this be the motor? Any suggestion???
Thank's
  • MINOSOTA Jan 19, 2008
    I TURNED ON THE VACUUM, IT STARTED SMOKING AS SOON AS I TURNED IT ON, AND THERE WAS A SMELL LIKE BURNING RUBBER.
    I TURNED THE VACUUM OFF VERY QUICKLY
    I HAVE SINCE TRIED TO TURN ON THE VACUUM CLEANER AND THERE IS NO RESPONSE AT ALL NO LIGHT NO ANYTHING
    I HAVE CHECKED TO MAKE SURE THERE IS NOTHING JAMMING THE MOTOR, THE FRONT SHAFT SPINS EASILY THERE IS NOTHING BLOCKING THE FRONT INTAKE
Marci Marple
Level 2:
  • Expert 357 Answers
  • Posted on Nov 09, 2007
Marci Marple
Expert
Level 2:
Answers
357
Questions
Helped
172113
Points
543
The carbon brushes in the motor need to be replaced. Very IMPORTANT....... DO NOT run the Kirby anymore until you get this fixed. If you do, the armature will be in danger of being damaged. (and that part is expensive!) The carbon brushes are reasonably priced, and you can use this online guide to get to them and change them. It's a guide for replacing the power switch, but it will help you change the carbon brushes too. Hope I've helped...
Marci
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Kirby G5 only works when the power button is being pushed.
power switch damaged contact your local kirby agent for repair
tip
How To Attach The Carpet Shampooer To A Kirby Generation 5 (G5) Vacuum Cleaner
The Kirby carpet shampooer is an attachment that is used with the Kirby upright vacuum cleaners. It converts the Kirby from being used as a dry pickup vacuum, into a carpet shampooer and extractor. Unlike other carpet shampooers and carpet extractors, the Kirby shampoo system does not saturate the carpet with a lot of water when cleaning. Kirby shampoo systems use a special dry foam formula that gently cleans the carpet without saturation.
Installation
The link below is to an excellent, easy to follow and understand video that will explain step by step how to convert the Kirby Generation 5 (G5) from a vacuum cleaner into a carpet shampooer. Please note that the vacuum in the video is actually a newer Sentria model, however the repair procedure is identical on the G5 as it is on the Sentria.
Video Demonstration of Converting Kirby Generation 5 From Vacuum Into Carpet Shampooer:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
If you have any questions about the procedure of converting the Kirby G5 into a carpet cleaner, please feel free to request clarfication on this video right here on the Tip page. I hope that this video was helpful. If you did find the video helpful, please kindly rate this Tip as helpful by clicking on the Thumbs Up Icon in the lower right hand corner of the page.
Thank you very much for watching,
Chris J.
I need a owners manual for a Kirby G5 vacuum cleaner
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
Kirby G5 Owner Manual
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
1helpful
Hi, my kirby makes a very loud and rattly noise when im vacuming, and sometimes the roller brush stops working, please help thank you
replace fan,belt and either clean ends of rollerbrush of string, hair, floss, etc or buy a new rollerbrush
1helpful
Not sure about the parts and what they do
Hi There,
First for your Shampoo attachment, all Kirby generation models came with this carpet shampoo attachment. It really does do a nice job at cleaning carpeting and rugs. In terms of how you use it, here's two links for you, the first is written instructions on how to use it, and the second is a video that shows you how to attach it to your Kirby and use it. In the video it's actually the Kirby Sentria that they use, but the procedure on converting it from a vacuum into a carpet cleaner are the exact same for the Sentria as they are for your G5.
Written Instruction Manual For Kirby Carpet Shampooer
Video Instructions On How To Install & Use Kirby Carpet Shampooer Attachment.
Now in terms of the other part that you were asking about. I believe the part your asking about is called the Intake Guard. I think this is the part that you're asking about, here's a picture of the Intake Guard:
The Intake Guard is connected to the front of the machine only when you want to convert your Kirby from a vacuum cleaner into a blower. This protects anything from going into the fan while it's being run, as well as pushing the safety switch that allows the machine to turn on.
I really hope that this information was helpful to you. If you have any follow up questions, or need further help with your new Kirby G5, please don't hesitate to add a comment here on the Fixya repair page, and I'll be more then happy to answer any and all of your follow up questions.
If you found my repair helpful to you, please be so kind and rate my repair helpful, or leave feedback. This is greatly appreciated by the Fixya community.
Thanks again,
Chris Jones
GoVacuum.com
HOW DO YOU CHANGE THE BELT ON THE G5?
Hi There,
Here's a helpful video that we recorded showing you exactly how to replace the belt on the Kirby Generation vacuums, step by step. This video will also show you how to do the basic maintenance on the roller brush to prolong the life of the belt as long as possible.
If you need to still purchase the belt for your Kirby G5, here's a direct link to our website to the belt that your machine uses:
Kirby G4 & G5 Vacuum Cleaner Belt. Kirby Part # 301291A
Here's the video repair presentation:
Please feel free to ask any follow up questions if you need help, I'm always more then happy to answer any question you may have. If you found this helpful, please be so kind and leave feedback, and / or rate my repair helpful.
This is greatly appreciated, and keeps Fixya experts continue posting free repair advice here on Fixya.
Thanks so much,
Chris Jones
GoVacuum.com
2helpful
How do we convert our Kirby G5 vacuum into the shampoo part?
Hi There,
Here's a link to a very helpful video that explains step by step the exact procedure to convert your Kirby into a carpet shampooer.
If you ever need to purchase the dry foam shampoo made specifically for Kirby vacuums, we have a great selection and prices (free shipping both ways):
Kirby Carpet Shampoo's & Cleaning Products
Here's the videorepair link:
I hope this was helpful to you. If it was helpful, please be so kind and leave some feedback, thank you.
Chris J.
GoVacuum.com
Replacement front and rear bearings on main shaft
usually you replace the rear bearing and the complete front bearing cover assy. the rear bearing will have to be pressed off and the new one pressed in, let me know how deep you are into the project so i know where to start.
1helpful
3answers
I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
4helpful
Engaging belt on Kirby G5
first things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. The hook stretches the belt so that it can fit over the fan drive.
Next, place the two "feet" of the powerhead onto the "perch" on the front of the kirby....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
then turn the belt lever from off to on.
the G5 should have a light on the powerhead that comes on (green) if the belt is spinning the brushes. That will let you know if you've got it on correctly.
Dec 24, 2007 • Vacuums
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
