It beeps 5 times quickly flowed by 6 slower beeps can any one tell me is it my mobo, Cpu or my gpu Im needing to know what to fix first
Here is a list of beeps that can help you:
1 beep BIOS ROM checksum in progress or System board failure
2 beep No memory modules detected
3 beep System board failure. Power LED is blinking amber
Time-Of-Day Clock test failure
Gate A20 failure
Super I/O chip failure
Keyboard controller test failure
4 beep Memory failure
5 beep CMOS battery failure
6 beep Video card failure
AK
SOURCE: XPS 600 - Six Beeps No Boot
Follow this link and figure out what the beep code is telling you and i can try to help you fix it from there. I can tell you that what you are describing usually is caused by a hardware issue.
http://www.computerhope.com/beep.htm
SOURCE: dell dimension 8400 beeps 6 times monitor dosen't turn on
Below is a link to the beep and light codes for a Dimension 8400. Check your codes and reply back if you need further assistance.
http://support.dell.com/support/edocs/systems/dim8400/SM/adtshoot.htm
SOURCE: Dell XPS 730 - Brand New - No display - Fan Loud
check if u r able to open the optical drive if its opening then power supply is gone bad or else get mobo an power supply replace
SOURCE: Dell XPS 410 will not even bring up Bios start up
6 long beeps is a Ram Memory problem.
Suggest this;
1.Computer off, unplugged from power. Computer case open.
2.Work on a table, touch the metal frame of the computer case. Doing this will relieve static. Your body carries Static, and Static will fry out computer hardware components in a Flash! You won't see it or feel it!
3.Remove all Ram modules. ('Sticks') Now reseat them. Be sure they/it are seated in all the way, and the lock tabs are clicked in on both sides of the ram stick.
4.Remove the CMOS battery. Press the Power On button in, and hold it in. Hold it in for a count of five seconds. Let go of the button. Do this two more times.
(You are clearing any CMOS Error Codes, and resetting BIOS back to the factory default settings. Some computers have a capacitor besides the CMOS battery, and will store a charge. Pressing the Power On button in the procedure stated above, will help to ensure that all residual power is drained. If you do not clear the CMOS Error Codes, you will wind up with the same problem)
5.Replace the CMOS battery. Close the computer case. Plug the computer back into power.
WAIT 1 minute. Turn the computer on.
I would like to know your findings. Should you still want to replace the motherboard, I have some recommendations. Dell doesn't state what form factor the motherboard in the XPS 410 is. I suspect it to be a Micro-ATX form factor. To be sure measure it.
1.ATX form factor: 12.4 inches by 9.6 inches
(305mm by 244mm)
2.Micro-ATX form factor: 9.6 inches by 9.6 inches.
(244mm by 244mm)
Let's start by the size of the motherboard first.
The motherboard chipset, (Northbridge/Southbridge chipset) used in the Dell XPS 410 is the Intel P965 Express chipset.
(Not bad really, but I prefer Nvidia motherboard chipsets. Why? Because you have a lot more options to tweak the system. The Nvidia 750i MCP chipset is a really decent one. So is the Nvidia 680i LT, and the Nvidia 780i)
SOURCE: My computer is a dell
6 Beeps in your Studio XPS 8100 computer indicates Video Card failure.
The Motherboard is unable to detect the Video Card properly or not at all.
Try removing and re-seating the Video Card by following the instructions in the link which opens up the Service Manual of the computer:
http://support.dell.com/support/edocs/systems/studio8100/en/index.htm
If the computer still behaves the same way after removing and reseating the Video Card, you may have to get the Video Card replaced...check with Dell about the Warranty and if the computer is still covered under warranty, get the Video Card replaced.
However, if the computer is out of warranty, you can replace the Video Card in the computer with any one of these as per your choice:
ATI Radeon HD 5770
NVIDIA GeForce GTX 260
NVIDIA GeForce GTS 240
NVIDIA GeForce GT 220
