Tv wont turn on by remote unless i unplug it how do i get it to work right without having to keep unluging it first then it works only a few times by remote then when it dont turn on by remote i have to unplug it till the light goes off an then plug it back in to work remote an it blinks 4 times before it turns on
Sounds like a button problem, your remote seems to be in programming mode,
I would take apart and clean,
Take batteries out 1st.
# 2 Take a Q tip with rubbing alcohol and swab your keys.
# 3 use some compressed air to blow out and dry keys.
# 4 Re- set your TV to factory reset.
Power tv up and follow instructions to remote set up.
SOURCE: I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
SOURCE: I have an emerson LC320EM9 HDTV it recently quit
Look at the power supply first, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
SOURCE: I have an Emerson LCD
Tries tv unplug,replug it back like about an hour later.The tv now it resetting itself back to factory setting should work again.If have the same problems,the tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
SOURCE: Emerson tv light repeatedly flashes green then doesn't turn on
This sounds like a very common issue.
If set is hard to turn on (takes several tries)but will eventually turn on hereis what my guess would be.
Every set has a standby power supplythat is running 7/24 if the set is plugged in and it supplies voltage to theremote circuit that turn on the main power supply for the tv and hence turn theset on.
This is an area where companies cut corners by using lower rated voltage caps.By this I mean Standby usually provides under 10 volts to trigger the seton----what they do is use filter caps rated at say 10 volts max in a circuitwith 9 volts (example)=with the standby on all the time the filter caps(electrolytic caps) dry out and fail.
The problem usually begins where you have to turn set on or or two times andgradually gets worse--takes longer and more tries to get it to come up.
Once on it will stay on until turned off for a period of time.
The caps will begin to work better (regain some of thecapacitance) as they get hot--hence one it is on it will seem ok.
The beauty of this problem is most of themhappen when set is a year or two old (no warranty) and all you have to do islook at the top to locate bad ones.
They are generally black or blue and round and vary in --they have twoconnections each--a + for positive and a - for negative--not unlike a batterywhich in a way they are. The + and - are marked on top and bottom of most boards.
They are easy to replace and not expensive parts.
The tops are silverand metal looking with creases on top and if bad they will be puffed up ontop---tops must be perfectly flat with no brown material leaking top or bottom.
If this is your problem once you id them (make a drawing) you can begin.
Here is the critical part---on each cap is also marked the value like 220uf 10vdc---220 micro farad at 10 volts maximum.
If you find for example 6 puffed up and all are 10 vdc replace them with thesame value capacitance (like the 220 uf) but go up to at least in this case(from 10 volts) to a 16 or higher rated voltage cap.
The only issue is when you go up in voltage rated value the cap is larger sosometimes there is an issue of physical space for the replacement on the boardto fit them in.
The reason they cheapen these sets in this way is if 10 caps and you make25,000 sets there is a considerable savings in parts cost.
They do not care as long as it lasts past the usual one year parts warranty.
I have taken the time to be long winded because this really sounds like it maybe the problem you have.
See attached photo of a typical cap and if you have questions or need advicelet me know.
