Came with both a DVD and floppy (3.5) drive. Forgot how to switch them out
SOURCE: can we change dell latitude c610 floppy disc drive for advd drive
Yes you can. On the bottom of the laptop there are 2 slide releases, one releases the battery the other is for the multi bay. With the computer off just slid the release and the drive will slide out forward. You can pick up dvd drives on Ebay and other sites for about $30.00 and you can even get dvd burners for your machine. If windows is running you can look in the bottom right corner and click on the eject hardware icon and stop the floppy or cd/dvd drive and eject the drive with the machine on. If the laptop is on you do need to stop the drive before you eject it or you can damage the drive and the laptop. I hope this helps you, if so please rate my solution.
Buddy
Corporate Computer
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
don
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
