Depending on your laptop, the internal splitter may be turned of. Usually the keystroke to turn it on is Fn F8. However it may be different on your laptop. Look at the function buttons, and the one with a screen looking thing on it is the one you press with your "Fn" key.
Well first check the colour scheme of your monitor and of the projector. If this doesn't work check the working hours of the lamp. Try cleaning the filters and if this doesn't solve your problem the best thing to do is to change the lamp of the device. If you need further assistance please leave a comment. Cheers
My TDP-T9 had the same symptoms. A 3300uF 10V electrolytic cap in the power supply (Liteon) unit was domed up, so I replaced it with a high-spec 2200uF 16V cap costing three dollars. The re-flow solder on the board was damn hard to melt though, needed 400°C setting on the soldering iron.
Yp-t9 only plays svi files.First make sure the videos you have are mp4 or avi or wmv.Then open samsung media studio.If u dont have it then download it.After that put the videos in your yp-t9 using the samsung media studio.The samsung media studio should convert those files into svi format which can be read by your yp-t9
Right click on your desktop , go to properties and settings - check if your resolution of the PC is the same as that of your Projector. i.e. 800x600 or 1024x768
Also check that your secondary monitor is attached / activated.
If the signal stil won't pick up - hold down the Fn ( function button) left of your spacebar and press in your F-row of buttons the one with 2 screens on it. ( differs from brand and model )
Hope this helps you and good luck with your class tomorrow !
i cannot down load driver from your site for my ipod which model no-is yp-t9j and it capacity is 2 gb . please give me advise how should down load this driver for my pc.thanks
