Came on momentarily then no output
SOURCE: generac model # 09734-1 no voltage output. would like a manual
Flash the fields. Remove front cover from the generator end. You will see the brushes and rings on the rotor. The ring closest to you is positive and the ring closest to the rotor windings is negative. With a 12 volt batttery and the generator running, place the positive side of the battery to the ring towards you and negative to the back ring. Make sure to use jumpers and keep fingers away from rotating parts and don't get zapped. You should see output voltage increase. If it does, your voltage regulator is bad, if it doesn't your generator end is bad.
SOURCE: My Generac Primepact 50 RV generator has no AC output.
Check the exciting field wires and fuses.
