Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
A
Anonymous Posted on Jul 16, 2014
Llight in upper unit will not come on when door opens, bulb ok
Light came on occationaly, then not at all.
Marlene
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 17, 2014
Marlene
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
66
Points
I have the same problem
How do I replace bulbs on model DS5603 Mod G electric fireplace
Do you need to replace the upper or lower light bulbs?
For both, first open the door of the fireplace. For the upper light, locate the upper bulb bracket (above the door). Bend the bracket down. Unscrew the old bulb and replace it with 7 W clear chandelier or candelabra bulb with an E12 base. Bend the bracket back up to its original position. Close the door, if only the upper bulb is out.
You will need a Phillips blade screwdriver to replace lower bulbs. Open the door (if it wasn't already open). Locate the screw that holds the log set in the center of the ember bed. Remove that screw and the log set. Locate the bulbs that are behind the log set and determine if one or both bulbs need to be replaced. Unscrew the bulb(s) to be replaced. Screw in the replacement 60 W clear chandelier or candelabra bulb with the E12 base. Replace the log set and press firmly against the glass. Replace the screw that holds the log set. Close the fireplace door.
The procedure to replace the bulbs is on page 4 of the service manual. It is also on pages 10-11 of the Owner's Manual. The documentation is available from Dimplex: http://www.dimplex.com/en/customer_support/technical_and_troubleshooting . The direct link to the service manual is http://www.dimplex.com/cms/publications/7400650000R04.pdf . The Owner's manual is here: http://www.dimplex.com/cms/publications/7206570100R09.pdf .
I hope this helps.
3answers
INTERIOR LIGHTS WILL NOT COME ON WHEN I OPEN THE DOOR, TURN OFF THE ENGINE, ETC
Is bulb/fuse ok?
If so could be the door swich. Have you tried the opening the other door?
Replace door switch
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Before you change you door light switch. Lets check it out. First, if you have changed the light bulb, did you use a refrigeration light bulb. These bulbs sometimes are available in your local food market. If you used a household light bulb it eventually will fail. The household bulb is not designed for cold temperatures.
All appliances require specific light bulbs designed to the application such as, refrigerators, freezers, dishwashers, clothes washers and dryers. Of course they are more expensive $8.00-$10.00.
Ok, lets assume you have the correct appliance light bulb in your refrigerator. With the door open push on the door light switch. If the light comes on your door switch.
All door switches are basically the same they are plastic two contacts, except for one that is a 3 contact switch. The third contact controls the ice dispenser. This switch is on the left side of the freezer wall (Liner).
Ok, lets change a door light switch. Unplug your refrigerator. With a small flat head screw driver (or butter knife) wedge behind the plastic switch frame. Pop it out. Be careful, do not pull it out too far. You will see the two connectors. It may be difficult to remove the connector, so wedge them with a flat head screw driver (Or butter knife). Do not pull on the wires, just the metal connector.
Ok, with your particular model the contact switch is on the top of your unit. There are two screws holding the hinge cover plate. These screws are either Phillips head or hex head. Either 1/4" or 5/16" hex head. Remove the hinge top cover. You have one on each side. There is a connector. With a small screw driver, wedge into the connector to release it. The rest is yours.
Peter, Glen Burnie, Maryland, USA
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
1helpful
How to open genie 1/2 hp garage opener for light bulb
Set a step ladder under the power head of the garage door opener so you can reach the power cord and the lens cover safely.
Climb the ladder and pull the power cord from the outlet in the ceiling. Press the two lens tabs in to disengage the lens from the power head. The lens tabs are below the opener rail on the upper corners of the lens. Pull the lens cover straight off of the power head.
Unscrew the light bulb from the light socket. Use a new 60 watt bulb to replace the defective bulb. Do not use a short neck bulb. Screw the new bulb into the light socket just as you would a regular lamp socket.
Slide the lens cover back over the front of the power head. Push the lens cover in until the locking tabs engage the top corners of the lens cover.
Plug the Genie garage door opener power cord back into the ceiling electrical outlet.
home light
2helpful
2answers
My blinkers don't work. where is the fuse? or whatever make it blink!!!
Look on the side of the dash when you first open your driver side door, or under the steering column. Unlikely, but some models actually have the fuse panel in the glove box.
Definatley check the fuses, but dont forget to change out the actual bulbs. be sure replace them with the same # that is printed on the bulb.
2helpful
Blowing out light bulbs
There are rough service bulbs you can buy at hardware stores. You can also try unplugging the unit and using a small screwdriver pull out on the center contact in the light bulb socket.
3helpful
3answers
I have a Lift Master 1160. It opens when my
To erase the memory press and hold the smart/learn button on the back of the motor unit for 10 seconds. This will stop any remote or keypad from opening your door. To program it press and hold the button on your remote and then press and immediately release the smart/learn button. Do this for each remote you have.
2helpful
Light bulbs constantly burn out in Chamberlain Garage Door Opener
Unplug the unit from the power and take a screwdriver and pull out on the center contact of the socket.
Garage door opener
Unplug the unit and look inside the socket. there is a copper lead you can bend up as it might not be getting a good contact. If that is not it you can start by replacing the socket itself from the manufacturer. If that does not do it then you will have to replace the logic board. Whether you reair or replace get a surge protector on this unit 900 joules or higher. Thanks BB
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
