HDMI1 AND HDMI2 CONNECTIONS NO SIGNAL
SOURCE: Samsung T220HD - can't access HDMI input sources
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck.
SOURCE: Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Sounds like a main board issue.
Testimonial: "Thanks for the quick response richie46! Could you elaborate on your troubleshooting logic? Trying to justify buying a replacement board."
