First check the fuse that powers the heating elements, and then check the resistance of the heating elements must be between 75 to 1200 ohms. I hope that the fans are operating
The disgusting smell is from using too much detergent, using softener or from using only cold water for washing.
The area of buildup is just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this area: http://www.youtube.com/watch?v=Ua6OJPn0-fU
The added bulk of the laundry will raise the water level to include the "splash area" intermittent pausing to soak is also a good tip in extreme cases.
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
check the duct work going out of the house if it is clogged the clothes wont dry. Birds love to build nest in a open dryer vent and if you have any bends lint will build up get these clean and it should get you drying again let me know what you find bill
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
