Im playing a game and i have no idea where the mic is on my laptop. like is it under??? on the side????? where is it (also i couldnt find my actual product on the product fix thing sorry)
SOURCE: microphone is not working
You need to check that all of your sound devices are enabled. Most laptops will shut down certain devices when on battery to conserve power.
There are setting available to alter the microphone gain in the sound settings part of the control panel. Under Sounds and Audio Devices Properties. Check the sound recording section under audio, make sure the microphone is enabled and that the volume slider is not at minimum. Under XP there is a test hardware button that should help.
SOURCE: My external microphone jack and USB's doesn't work on Toshiba Satellite
hi, double click on the speaker icon on the bottom right corner, go to options, recording and select the microphone and adjust the level suitable.. thats it.. let me know
SOURCE: Microphone issue with "Toshiba Satellite A135 4656" with XP
Most of the drivers can be found here:
http://il.computers.toshiba-europe.c...jsp?service=IL
Select: Notebook
Select: Satellite Pro
Select: Satellite Pro A Series
Select: Satillite Pro A200 (PSAE1)
Select: PSAE1
Select: Windows XP
Select : Search
This model has the same Chipset Drivers as the A135-S4677
You will need XP SP2 (NOT SP3)
The LINK will show you alot of drivers, but follow this order by make and version #
Chipset Utility: INTEL 7.1.0.1014
Display Driver: Intel 6.14.10.4833
LAN Driver: Realtek 5.664.205.2007
Wireless Driver : Atheros 5.2.0.125
Sound: Realtek 5.10.0.5464 (Next page)
Modem: You will have to select you region
SOURCE: Toshiba Satellite L505-S5966 internal built-in
have u only used messenger to test your mic? try other applications like a voice recorder, and see if yer mic will pick up there. if it does, then mabey u have the wrong version of messenger like if u have 32 bit or 64 bit version of windows. if it doesnt work, then you have a driver error and u can go into start>control panel>device manager>and other computers are different, but i'd go into imaging devices cuz my cam and mic are a full set of drivers together but see if you have a microphone on there. if not, then look at wot u can see that has any possible relation to a microphone, and select "update driver software" and it'll go online for ya and see if the drivers are up to date. and if its not the driver, then its your mic itself, and hopefully your under warranty, or if not, then just pay some money and get it fixed.
SOURCE: How do I use the built in microphone in my Toshiba
of course it is possible,go to official site(toshiba),select Support & Downloads then select your laptop type,O.S. and webcam driver then download ,instal and then you can test it ,then configure skype to microphone.
