Question about Dell 2150cn / 2150cdn / 2155cn / 2155cdn Color Laser Printers
How to print black only, yellow is out? - Dell 2150cn / 2150cdn / 2155cn / 2155cdn Color Laser Printers
  • Dell Master
  • 3,904 Answers
Most printers will not allow you to print without all cartridges active. If you printer is capable of that you can go into the printer settings on the control panel and go into options or print menu. Under that you can select B/W printing only. Try that out.
Posted on Jul 17, 2014
Prints yellow instead of black
I had the same problem with my Brother MFC 490 CW. It suddenly started printing yellow instead of black. I believe my problem was cause by a mislabeled third party black ink cartridge. The cartridge was labelled black but it had a yellow end piece. In any case I took out the black cartridge and replaced with another. Initially it made no difference I assume because some yellow ink was still in the tube. After 10 or so pages of printing the print turned darker. I also did three cleanings and unplugged the unit and then plugged it back in. I am not sure what if anything these latter two actions accomplished, but I wanted to report all I did in case they were actually part of the solution. My own conclusion is that it was simply a mislabeled cartridge.
Dec 05, 2011 | Brother MFC-290C Multifunction Color...
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Will not print black...Joe
check the printhead.... print a print quality page from the settings button select print reports then print that page. there is a printhead health area as well as color blocks if there is streaks in the black yellow blocks or says poor the black/yellow printhead needs to be replaced. if it says good call hp for further troubleshooting and possible replacement under warranty
Mar 31, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My copier is printing yellow throughout the page when it shouldnt
all colour empty in your cartridge. only yellow colour is in. so all printing is yellow. black colour cartridge too empty.
Feb 25, 2010 | HP Officejet Pro L7650 Printer
Out of yellow ink but only want to print in B&W
please you use the coloue paper print other black and white paper print ?
but you use the only yellow paper print ?
you refling the colour cartridge and setting page in colour prints
and use printer.
Sep 27, 2009 | Brother MFC-260C All-In-One InkJet Printer
Colors are not printing properly
Looks like your printer head is in need of replacement
Nov 11, 2008 | Canon i950 InkJet Photo Printer
Fax says to replace yellow cartridge...
There is a menu prompt that allows you to choose to print in black only.
Sep 16, 2008 | Office Equipment & Supplies
Yellow Prints in the other colors
Problem seems to be with your Ink Tank(s) or Printing Head. Replace both of them one by one and retry.
Jun 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Cannot get yellow to print
I had the same problem with the yellow cartridge. Yellow quit printing, put in a new yellow and still would not print yellow. I had a help file, don't know where I got it, but it suggested replacing the black ink cartridge also, even though the black wasn't low yet. Replaced the black, ran a few nozzle cleans and everything worked fine. Don't know why. Try it
Mar 03, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Dell 2150cn / 2150cdn / 2155cn / 2155cdn Color Laser Printers Logo
129 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Richard C Cohen
Richard C Cohen
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
