I can not get the subtitles off the tv .It just appeared on the tv . The button with subtitles does not get it off. I have lost the manual book for it . I have tried pressing the subtitle button but nothing has happened.
Scroll through the menu until you find a "closed caption" setting, sometimes written as "CC." Click the "Enter" button on your remote control to modify the settings. Turn offthe television subtitles by selecting the "Off" option.28 Sep 2017
From what I can gather on the link below (page 17), the on/off button appears to be on the back panel left side. Push the centre of the button for two seconds and you're good to go.
If you fail to do this; and all other functions are working properly; try an other set-up code to your device, with this remote control. This is a trial and error method. Check all the set-up codes, and choose one; which give you maximum functionality with your TV. This is true to all universal remote controls.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/
it is quite easy to play those anoying subtitles
first name the same way both files (video file and subtitle file)
example
movie.avi
movie.srt
be sure that both files are in the same folder
second:
insert the cd/dvd in the yht-630
when the menu appears select the subtitle file using the arrow keys and press the "subtitle" key after this at the screen you will see -> subtitle selected
finally select the file that contains the movie (again arrow keys) and press "ok" or "play " key
the movie will start and the subtitles will appear.
it functions with sub and srt files
