Cars & Trucks Logo
A
Anonymous Posted on Jul 15, 2014
I'm looking for torque spec for flywheel nut and head bolts for 1988 evinrude xp 150 v6
steve
Level 3:
  • Cars & Trucks Master 3,718 Answers
  • Posted on Jul 16, 2014
 steve
Level 3:
Answers
3718
Questions
Helped
964402
Points
12533
Follow this link for the head bolts , the fly wheel will be between 75-95 newto meters, click on torque tables
http://www.speedwayautoparts.com/index35.htm
1 Related Answer
Anonymous
  • 74 Answers
  • Posted on Mar 10, 2010
SOURCE: Need Cylinder head bolt torque specs and sequence
  1. Install the cylinder head gasket. Ensure the arrows point towards the front of the engine. The left cylinder head gasket has the letter L stamped next to the arrow.
  2. Notice
  3. This bolt is designed to permanently stretch when tightened. The correct part number fastener must be used to replace this type of fastener. Do not use a bolt that is stronger in this application. If the correct bolt is not used, the parts will not be tightened correctly. The system or the components may be damaged.
  4. Install the cylinder head.
  5. Install new cylinder head bolts. Tighten
    Tighten the cylinder head bolts to 50 N·m (37 lb ft) in sequence.
  6. Use the J 36660-A to rotate each cylinder head bolt 120 degrees in sequence. Use the J 36660-A to rotate the four center cylinder head bolts an additional 30 degrees in sequence. Refer to Notice Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
1997 Ford Festive Engine and Suspension Torque Specs
Here are some general torque specifications for the 1997 Ford Festiva's engine and suspension components. However, please note that these specs can vary based on the specific model and engine type. It's always best to refer to your vehicle's repair manual for precise information:
**Engine Torque Specs (in foot-pounds):**
- Cylinder Head Bolts: 35-50 ft-lbs
- Exhaust Manifold Bolts: 13-16 ft-lbs
- Intake Manifold Bolts: 18-24 ft-lbs
- Main Bearing Cap Bolts: 51-61 ft-lbs
- Rod Bearing Cap Bolts: 23-27 ft-lbs
- Flywheel Bolts (Manual Transmission): 58-73 ft-lbs
- Flywheel Bolts (Automatic Transmission): 61-76 ft-lbs
**Suspension Torque Specs (in foot-pounds):**
- Ball Joint Nut: 30-40 ft-lbs
- Control Arm Bolts: 60-80 ft-lbs
- Shock Absorber Upper Mount Nuts: 14-21 ft-lbs
- Shock Absorber Lower Mount Bolt: 40-55 ft-lbs
Remember that these values are approximate and can vary based on the specific model and any modifications made to the vehicle. Always refer to your vehicle's repair manual or consult a professional mechanic for accurate torque specifications to ensure proper installation and safety.
2008 chrysler 300 touring 3.5 v6 head cam bolts what are the torque specs
It is all here complete with pictures and diagrams. A Service Manual of your own is a great investment as stated by our Pro Tech Larry Ng.
https://www.google.com/search?q=2008+chrysler+300+touring+3.5+V6+head+camshaft+bolt+torque+specs
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Torque spec's for the fly wheel
2answers
Cylinder head torque specs for kia carnival 2002 2.5 v6
cylinder head the torque is : step 1 55 ft-lb, step 2 65 ft-lb, step 3 85 ft-lb. Rocker arm stud nut or bolt is 17 to 23 ft-lb. and valve cover bolt 72 to 108 in-lb.
3helpful
V6 T3000 need torque specs has throttle body injector
3.0L and 3.5L V6
Torque Specifications
air intake plenum 11-14 ft lbs.
camshaft bearing cap 14-15 ft lbs.
connecting rod nut 37-38 ft lbs.
camshaft sprocket bolt 66-67 ft lbs.
crankshaft pulley bolt 108-116 ft lbs.
cylinder head bolts 65-72 ft lbs. ( 3.0L) 76-83 ft lbs. (3.5L)
drive plate ( flywheel ) 53-55 ft lbs.
exhust manifold 11-16 ft lbs.
intake manifold 11-15 ft lbs.
main bearing cap 55-61 ft lbs.
rocker shaft 14-15 ft lbs.
valve cover 27-35 in. lbs.
throttle body bolt 84-108 in. lbs.
8helpful
I have 4.9L6 need torque specs for cylinder head
for cylinder head the torque is : step 1 55 ft-lb, step 2 65 ft-lb, step 3 85 ft-lb. Rocker arm stud nut or bolt is 17 to 23 ft-lb. and valve cover bolt 72 to 108 in-lb.
1helpful
Head bolt torque spec and sequence
Torque to yeild bolts need to be replaced whenever the head comes off.....Long bolts are 46 ft lbs. and the turn 90 degrees (1/4 turn) short bolts are 43 ft. lbs. and then 90
5helpful
Looking for the torque specs for 1998 chevy astro van?
1998 chevy astro 4.3 v6 torque specs include :
* foot pounds *
balance shaft (if equiped) gear bolt = step 1 = 15 ft.lbs. step2 = additional 35 degrees.
camshaft sprocket bolt = 18 ft. lbs.
connecting rod cap = step 1 = 20 ft. lbs. step 2 = additional 70 degrees.
crankshaft damper bolt = 74 ft. lbs.
crankshaft oil deflectorbolt/nut = 27 ft.lbs.
cylinder head bolts = step 1 = 15 ft. lbs. step 2 = additional 73 degrees. (tighten in sequence)
exhaust manifold bolts = step 1 = 11 ft. lbs. step 2 = 22 ft. lbs.
flywheel bolt = 74 ft. lbs.
main bearing cap bolts = step 1 = 15 ft. lbs. step 2 = additional 73 degrees.
oil filter adapter bolt = 15 ft. lbs.
oil pan bolt/nut = 18 ft. lbs.
oil pump bolt = 66 ft. lbs.
rocker arm with press in studs = 18 ft. lbs.
rocker arm with screw in studs = 19 ft. lbs.
valve lifter retainer bolt = 12 ft. lbs.
water pump bolt = 33 ft. lbs.
* inch pounds *
balance shaft retaining plate bolt = 106 in. lbs.
camshaft retainer plate bolt = 106 in. lbs.
front cover bolt = 106 in. lbs.
intake manifold upper = step 1 = 44 in. lbs. step 2 = 88 in. lbs.
intake manifold lower = step 1 = 27 in. lbs. step 2 = 106 in. lbs. step 3 = 133 in. lbs. ** (tighten bolts in sequence)
thanks for your vote !
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
