It does pump water into the pool via the side hole in the pool where the legend platinum hooks up. So to say its functioning is true but as the title states it sounds as water is spraying internally. its very loud. What part has failed?
SOURCE: Do I need a pressure tank with a Pentair Water 3/4Hp Pres Wtr System 3075Ss Utility Pumps?
Depends on your application. If you are using it to provide water to a residence or other on/off use, you need a pressure tank and a pressure switch to control it. If you are filling a open air tank, no pressure tank needed. If you are just pumping water out of a well and directly to an ditch type irrigation system no tank needed.
