I misplaced the instructions to the RCA TV remotes with the codes. Could you please provide me the codes to operate a Sansui Television. Remote: RCR311B
One more 'lost code list' person. I have a philips SRU 2040/17 universal remote and a sanyo tv. 'code seach' doesnt work, i need the actual 3 or 4 digit code. HELP! my kid wants to watch cartoons and i cant turn the tv from video back to cable.
The set had a bad vertical output IC and when the IC heated up it took out something in the power supply. Most likly in the sweep supply, that supplys the voltage to the vertical IC. If your not a tech, Please call one, as A TV set is not a place to experiment with. A good tech may even be able to repair the module as Zenths are made to replace the entire board when theres a service problem.. Go to http://ptscorp.com, click on technical assitance then finding the board you need by putting in the model # and this will come up with the board price to give you an idea on the replacement cost for parts and see if you want to invest that as well as the labor cost. Good Luck
