SOURCE: Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
SOURCE: I have the Echo 413H
Sounds like a carbuerator adjustment. Turn the low speed adjustment screw counterclockwise 1 guarter turn.(closest to engine block) Turn the high speed out the same (farthest from engine block). You may have to tweak it a little, those adjustments vary. Hope that gets ya going.
SOURCE: Need the air gap between
All magnetos work best with minimal air gap. Gap it with the thinnest piece of paper/plastic that you can remove from the gap. Spin it, examine flywheel for evidence of rubbing. If it's good, start it and zoom it a couple of times, shut it down and check again.
lp
